variableHeightFlowRateInletVelocity bubbles at the inlet
Old   October 7, 2019, 11:16
Default variableHeightFlowRateInletVelocity bubbles at the inlet
Grivalszki Péter
GrivalszkiP is on a distinguished road
I have a multiphase interIsoFoam simulation with variableHeightFlowRateInletVelocity inlet boundary condition for U.
When I watched the results I've noticed inflow bubbles at the inlet. It looks quite random.
Why are these bubbles? Are they normal? Can I do something against them? I'm afraid that these bubbles may affect my final results.
Here is a photo of the problem (but a video would be more effective I know...)
Thank you in advance!
Griva
GrivalszkiP is offline   Reply With Quote
Old   October 8, 2019, 04:45
Sita Drost
sita is on a distinguished road
Hi Griva,
I happened to come across exactly this in the Applied OpenFOAM course (CFD-Direct) I recently attended. The bubbles are a result of air being trapped at the inlet when the water level is rising at the start of the simulation. The good news is that this can be fixed, the sad news is that I can't remember exactly how... I think it was done by setting the initial volume fraction field not only in a boxToCell region, but also in a boxToFace region, to set the volume fraction on the inlet faces:
  \\      /  F ield         | OpenFOAM: The Open Source CFD Toolbox
   \\    /   O peration     | Website:  https://openfoam.org
    \\  /    A nd           | Version:  7
     \\/     M anipulation  |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    object      setFieldsDict;
defaultFieldValues
    volScalarFieldValue alpha.water 0
regions
    boxToCell
        box     (-5 -1 -1) (0.5 1 1.3);
        fieldValues
            volScalarFieldValue alpha.water 1
    boxToFace
        fieldValues
Hope this helps,
Sita
sita is offline   Reply With Quote
Old   October 8, 2019, 12:54
Grivalszki Péter
Unfortunately it didn't work... Can you please ask for the solution among your coursemates?
Thank you!
Griva
Old   October 8, 2019, 15:30
Sita Drost
Hi Griva,
Ah, that's too bad, I'm fairly sure that this was the solution that was used during the course. If you want I can send you the case we did in a PM, so you can compare and try things for yourself.
Sita
P.S. I'm not sure I can see those bubbles in the images you attached. Wouldn't a phase fraction plot be more suitable here?
Old   October 9, 2019, 04:11
Grivalszki Péter
I would be really grateful, thank you!
Old   October 9, 2019, 08:02
Sita Drost
Hi Griva,
The private messaging tool is throwing errors, so I put the case on Dropbox instead:
https://www.dropbox.com/s/j39gpxb4tx...rflow.zip?dl=0
I'm not sure whether the problem we prevented in this case is the same one you're encountering now, but hopefully it's useful to you anyway.
Good luck,
Sita
P.S. Please let me know when you've downloaded the case, so I can remove it from my Dropbox
Old   October 10, 2019, 07:55
Grivalszki Péter
Thank you so much, I've downloaded it!
Griva
Old   November 7, 2019, 11:14
Grivalszki Péter
It didn't work
Old   November 8, 2019, 06:30
Sita Drost
Ah, that's too bad, sorry to hear that! I'm afraid I can't help you any further in that case.
bubbles, inflow, inlet, random, variableheightflowrate
setting the correct format of nonuniform List<vector> for inlet in 0 Folder cfdonline2mohsen OpenFOAM Running, Solving & CFD 8 July 18, 2019 09:03
Adjuting oulet pressure till inlet pressure reaches a certain value in timestep pvpnrao OpenFOAM Running, Solving & CFD 2 September 11, 2018 11:14
multiple inlet as one inlet amin_gls CFX 2 October 2, 2013 09:59
velocity inlet and ideal gas simultaneously-what's wrong? preetam69 FLUENT 0 September 28, 2013 05:51
Inlet Velocity in CFX aeroman CFX 12 August 6, 2009 19:42
