Error continuing run from latest time with FaMesh |
October 4, 2019, 03:36 |
Riley
I have run a simulation with no problems and now I want to use the final time as a start time (the purpose of this is so my internal fields are correctly initialised before I adjust some parameters in the controldict and continue running. Obviously it is ideal if I do not need to wait for this initialisation period to complete on every run.). The issue is when I run my solver after the initial run using startFrom latestTime I get the following error: Code:
--> FOAM FATAL ERROR: S0 is not available From function const Foam::DimensionedField<double, Foam::areaMesh>& Foam::faMesh::S0() const in file faMesh/faMesh.C at line 1093. FOAM aborting #0 Foam::error::printStack(Foam::Ostream&) at ??:? #1 Foam::error::abort() at ??:? #2 Foam::faMesh::S0() const at ??:? #3 Foam::fa::EulerFaDdtScheme<double>::famDdt(Foam::GeometricField<double, Foam::faPatchField, Foam::areaMesh> const&) at ??:? #4 ? in ~/OpenFOAM/riley-v1906/platforms/linux64GccDPInt32Opt/bin/silicaROicoFoam #5 ? in ~/OpenFOAM/riley-v1906/platforms/linux64GccDPInt32Opt/bin/silicaROicoFoam #6 __libc_start_main in /lib/x86_64-linux-gnu/libc.so.6 #7 ? in ~/OpenFOAM/riley-v1906/platforms/linux64GccDPInt32Opt/bin/silicaROicoFoam Aborted (core dumped) |
October 18, 2019, 20:27 |
Riley
I managed to resolve this issue by including
mesh.update(); mesh.moving(false); before the solver loop |
famesh, latesttime |
[General] Extracting ParaView Data into Python Arrays | Jeffzda | ParaView | 30 | November 6, 2023 22:00 |
[solidMechanics] Support thread for "Solid Mechanics Solvers added to OpenFOAM Extend" | bigphil | OpenFOAM CC Toolkits for Fluid-Structure Interaction | 686 | December 22, 2022 10:10 |
AMI speed performance | danny123 | OpenFOAM | 21 | October 24, 2020 05:13 |
Extrusion with OpenFoam problem No. Iterations 0 | Lord Kelvin | OpenFOAM Running, Solving & CFD | 8 | March 28, 2016 12:08 |
How to write k and epsilon before the abnormal end | xiuying | OpenFOAM Running, Solving & CFD | 8 | August 27, 2013 16:33 |
