金恒
Rep Power: 13 ![]() |
Dear all,I have recently tried the coupling motion of multiple rigid bodies. Start with the simplest case---Plate A move by “tabulated6DoFMotion” or “oscillatingLinearMotion” or anything else. Plate B connect with Plate A using a spring restraint, like "linearSpring". For Plate A I can use tabulated6DoFMotion just like sloshing3D6dof case. While Box B I will use sixDoFRigidBodyDisplacement just like floatingObject case. when Plate was forced to move and box B was restraint by spring connect with wall. It work well.
My problem is: When I want connect Box B and Plate A using a spring. Both points of spring are flexable. How can I do ? I have already fellow the report http://www.tfd.chalmers.se/~hani/kur...Minghao_Wu.pdf to compile the couplinglinearspring make it possible to connect two floaingbox. But if one is forced to move and the other is 6dof? what can I do? Thanks for every reply and suggestion. My case files are listed bellow. Heng Jin |
How to define movement/deformation relative to a rigid body motion in Fluent by udf? | eagle_001 | Fluent UDF and Scheme Programming | 6 | May 17, 2022 03:41 |
How to set initial velocity for rigid body motion? | pbachant | OpenFOAM Running, Solving & CFD | 3 | March 27, 2020 08:18 |
Rigid Body Motion + Remeshing | Ganesh.aero | CFX | 7 | February 25, 2017 05:53 |
Dynamic meshing: UDF for rigid body Motion | Manoj Kumar | FLUENT | 0 | June 20, 2005 01:02 |
Rigid Body Motion in Eulerian Grid | Zi-Wei Chiou | Main CFD Forum | 0 | November 14, 2001 22:39 |
