chtMultiRegionFoam in of6 at High Speeds
Old   October 2, 2019, 06:27
Default chtMultiRegionFoam in of6 at High Speeds
Arslan Adeel Ur Rehmann
arslanadeel is on a distinguished road
Hi everyone!
I am trying to simulation flow over an airfoil using chtMultiRegion v6 at a high velocity 160ms-1. But the issue is the simulation explodes every-time.
I have already tried many things like initializing solution with rhoSimpleFoam, run at low velocity and mapping the solution nothing is working at a velocity above 10ms-1.
Does anyone has experience using chtMultiRegion at high velocities. Would love to hear your comments.
Thanks
arslanadeel is offline   Reply With Quote
Old   October 2, 2019, 08:27
Bloerb will become famous soon enough
High velocity is relative. Which medium is it? And what is the mach number of the flow?
Bloerb is offline   Reply With Quote
Old   October 4, 2019, 08:32
Hi
I am using air and Mach no is 0.5.
Old   October 4, 2019, 09:00
Are you using the transsonic switch? Which schemes are you using? What is the mesh quality like? What are your relaxation factors?
Old   October 4, 2019, 09:26
I have attached my fvSchemes and fvSolutions files. I am using chtMultiRegionSimpleFoam of5. My mesh quality is
MaSckewness : 0.15
Max Non-orthogonality : 50
max Aspect Ratio : 205
Old   October 4, 2019, 09:31
Try this:
    div(phi,U)      bounded Gauss upwind;
    div(phi,k)      bounded Gauss upwind;
    div(phi,omega)  bounded Gauss upwind;
    div(phi,h)      bounded Gauss upwind;
    div(phi,K)      bounded Gauss upwind;
    div(phi,Ekp)   bounded Gauss upwind;
If this works you can increase your schemes to second order one by one. Second order in everything is a bit ambitious for coupled energy systems.
chtmultiregionfoam, high speed, high velocity flow, openfoam6
Conjugate heat transfer high speed gas flow jaktry89 OpenFOAM Running, Solving & CFD 14 March 17, 2023 08:53
BC for Actuator Disk - Flow Vel from High Pressure to Low Pressure vinguva OpenFOAM Running, Solving & CFD 2 March 8, 2016 00:46
High Lift Airfoils At High Angles Of Attack Luiz Pancini FLUENT 2 April 9, 2015 09:01
Convergence of High Speed Turbulent flows satty_00 FLUENT 0 February 21, 2015 04:23
flow with high turbulent viscosity ratio Phillips FLUENT 0 August 24, 2008 19:01
