Complex velocity boundary condition
Old   October 2, 2019, 01:17
Default Complex velocity boundary condition
Pavithra is on a distinguished road
Hello Everyone,
I want to implement the following boundary condition on the horizontal walls of a 2-D square cavity.
\beta \frac{du_x}{dy} = (1-\beta)u_x
u_y = 0
The value of \beta varies from 0 to 1 in steps of 0.25.
I understand that when \beta = 0, the boundary condition becomes u_x = 0 and u_y = 0.
Also, when \beta = 1, the boundary condition becomes \frac{du_x}{dy} = 0 and u_y = 0.
I am able to achieve the above two cases using directionMixed boundary condition.
But I am unable to figure out how to set the boundary condition when \beta takes a value such as 0.25, 0.5 or 0.75.
For instance, when \beta = 0.25, it becomes \frac{du_x}{dy}=3u_x.
Kindly please give me some directions to implement this boundary condition.
Thank You.
With Thanks
Pavithra.
Pavithra is offline   Reply With Quote
boundary condition, directionmixed bc, openfoam, velocity components
The method on dealing with velocity in static pressure outlet boundary condition mona.li CFX 2 September 30, 2017 02:33
Massflow or average velocity boundary condition Sideshore OpenFOAM Pre-Processing 6 September 27, 2016 16:09
Problem in setting Boundary Condition Madhatter92 CFX 12 January 12, 2016 05:39
Boundary condition of velocity and pressure at interface for air water pipe flow jignesh_thaker2007 OpenFOAM Running, Solving & CFD 0 June 10, 2014 17:42
Question about heat transfer coefficient setting for CFX Anna Tian CFX 1 June 16, 2013 07:28
