External Aerodynamics Adjoint solver instability
Old   October 1, 2019, 05:37
Default External Aerodynamics Adjoint solver instability
Andrew
Astan is on a distinguished road
Hi guys, i would kindly ask for an advice, i don't know how to solve this stability problem.
I'm running an adjoint simulation on a car.
For the first 500 iteration, the simulation goes in the " right " direction, meaning that the all residuals decrease and the sensitivity does not exhibit any " crazy " behaviour.
From the 500th iteration on, the adjoint pressure residual does not decrease anymore and starts to increase in a monotonic way and so does the continuity error, too.
The checkmesh is ok, the maximum non orthogonality of the mesh is 64.44°.
I would kindly ask if you have any suggestion to solve this problem, the fvscheme and fvsolution are the following:
|  \\    /   O peration     | Version:  5                                     |
|   \\  /    A nd           | Web:      www.OpenFOAM.org                      |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    object      fvSchemes;
// Adj
ddtSchemes
    default         steadyState;
gradSchemes
    default         cellLimited Gauss linear 1;
    grad(Ua)        cellLimited Gauss linear 1;
divSchemes
    default         none;
    div(-phi,Ua)    Gauss upwind;
    div((nuEff*dev2(T(grad(Ua))))) Gauss linear;
laplacianSchemes
    default         Gauss linear limited 0.777;
interpolationSchemes
    default         linear;
snGradSchemes
    default         limited 0.777;
fluxRequired
    default         no;
    p;
    pa;
wallDist
   method meshWave;
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    object      fvSolution;
solvers
    "(pa)"
        solver          GAMG;
        tolerance       1e-6; // up 900
        //tolerance       1e-8; up 4300
        //tolerance       1e-9;
        relTol          0.001;
        smoother        GaussSeidel;
        cacheAgglomeration true;
        nPreSweeps      0;
        nPostSweeps     2;
        nCellsInCoarsestLevel 500;
        agglomerator    faceAreaPair;
        mergeLevels     1;
    "(Ua)"
        solver          PBiCGStab;
        preconditioner  DILU;
        tolerance       1e-8;// up 4300
        //tolerance       1e-9;
        relTol          0.0;
SIMPLE
    nNonOrthogonalCorrectors 	2;
    pRefCell        		0;
    pRefValue       		0;
    residualControl
       pa               1e-8;
       Ua               1e-8;
relaxationFactors
    fields
        pa                 0.05;
    equations
        Ua                 0.05; // lowering it can solve solver instability at startup
Astan.
Thanks you for the time spent in this thread, any suggestions are really appreciated
Astan is offline   Reply With Quote
Adjoint solver wing twist optimization!! mechesanjiv FLUENT 10 April 13, 2023 10:21
Fluent adjoint solver; Constant area constraint HHK FLUENT 2 April 12, 2023 07:07
[ANSYS Meshing] Help with element size sandri_92 ANSYS Meshing & Geometry 14 November 14, 2018 08:54
Where is my Adjoint Solver! HashemAlArgha FLUENT 1 August 28, 2016 05:11
fluent divergence for no reason sufjanst FLUENT 2 March 23, 2016 17:08
