Asymmetry is observed in wake for flow over a circular cylinder |
September 30, 2019, 21:46 |
suyash
Rep Power: 8 |
Dear All,
I've been conducting a simulation for a flow over a circular cylinder at Re = 20000, using OpenFOAM v1712, and without any turbulence modelling specification. The solver I've been using is pimpleFoam, with GAMG method specified in fvSolution dictionary. Ideally, I've never seen asymmetry in the wake for any of the published research studies, related to stationary cylinder. I am confused whether it has something to do with the numerical aspect of the simulation, such as the solver, spatial or temporal discretization scheme etc. The solution is always stable and does not diverge, and even the residuals are also converging well towards low values. The mesh is quite simple, and is similar to many previous studies. Can anyone provide some insights into what might cause an asymmetry in the wake, although other characteristics of the solution look good.? |
asymmetry, cylinder, openfoam, pimplefoam |
Problem with wake pressure for unsteady flow around circular cylinder | Bazinga | OpenFOAM | 2 | August 27, 2018 08:13 |
Cylinder motion along a circular path | karamiag | OpenFOAM Running, Solving & CFD | 0 | May 25, 2014 06:05 |
[ANSYS Meshing] Meshing 3d circular cylinder in ICEM | darazsbence | ANSYS Meshing & Geometry | 0 | March 11, 2014 17:35 |
Flow past 2 smooth circular cylinder | slip | FLUENT | 0 | July 8, 2010 19:45 |
[blockMesh] Grid generation cross flow over circular cylinder | Yanma | OpenFOAM Meshing & Mesh Conversion | 0 | July 7, 2010 09:02 |
