DNS turbulent initialisation
Old   September 30, 2019, 12:12
Default DNS turbulent initialisation
Nat K
nskelly is on a distinguished road
I was wondering what methods are there to initialize a DNS flow field? I am looking at the flow within a cone and plate rheometer and I am unsure of what ICs or OF utilities are best for adding some sore turbulent intensity or perturbations. Currently, the only methods I have seen are perturbU, but this is restricted to channel flows.
Thanks
nskelly is offline   Reply With Quote
Old   October 1, 2019, 05:15
Andrea
Andrea1984 is on a distinguished road
Hi Nathaniel,
I have obtained an initial isotropic turbulent condition for LES with boxTurb. As the name suggests, the tool only works for box-shaped domains, and there is the additional caveat that the mesh has to have 2^n cells. For non-box shaped domains with a generic number of cells I usually do the following:
-generate a box with 2^n cells which encompasses the domain
-use boxTurb to generate a nice turbulent field within the box
-use mapFields with the cuttingPatches option to map the turbulent field to my actual domain
Hope this helps,
Andrea
Andrea1984 is offline   Reply With Quote
Old   October 4, 2019, 12:16
Nat K
Hi Andrea,
Thanks for the reply. I read that using boxTurb is one method for initialising the flow. But I am a bit unsure of how the mapFields part works.
I want to look at the laminar-turbulent transition process. So how can I add the turbulent fluctuations to an existing simulation? The
For example:
If I want to run a simulation at Re = 2000 (where flow is in the transitional flow regime). Where do I put the the boxTurb field data? After some timesteps have solved or as the inital BCs?
Thanks
Old   October 5, 2019, 06:54
Andrea
I have never used boxTurb to superimpose turbulent fluctuations to an existing velocity field. The way I would use it is to generate an initial turbulent flow field and then run the simulation and let the "real" turbulence develop.
I am not sure this is the right thing to do in your case though, since you want to investigate transition and boxTurb is going to provide you with a fully turbulent initial flow field.
Andrea
dns, initialise, turbulence
Hairpin vortices in turbulent channel flow using DNS Nitin Minocha Main CFD Forum 2 November 21, 2016 18:52
Turbulent or laminar flow yansheng STAR-CCM+ 4 July 1, 2016 18:53
spectrum: LES of a turbulent channel flow finally goes to turbulent liu OpenFOAM Running, Solving & CFD 6 November 1, 2011 02:00
DNS in Turbulent S.O.S. Urgent Hengky FLUENT 11 September 28, 2006 11:07
How to obtain turbulent K.E. from DNS data? Boying Lin Main CFD Forum 5 December 16, 2003 06:40
