September 30, 2019, 11:17 |
bounadry conditions on p_pgh
Bagya Vivekanandhan
Rep Power: 7 |
hi,
I am trying to run a overInterDymFoam case and i have set up the required boundary conditions for the p_rgh file. but the solver shows an error that the patchtype and the type are inconsistent for the sides. any suggestions or advice regarding this would be appreciated. below is the file of p_rgh. THE ERROR BEING DISPLAYED IS : inconsistent patch and patchField types for patch type overset and patchField type fixedFluxPressure file: /home/utente/Scrivania/Bagya/mycase/floatingBody/background/0/p_rgh.boundaryField.sides From function static Foam::tmp<Foam::fvPatchField<Type> > Foam::fvPatchField<Type>::New(const Foam::fvPatch&, const Foam:imensionedField<Type, Foam::volMesh>&, const Foam::dictionary&) [with Type = double] in file /home/utente/OpenFOAM/OpenFOAM-v1812/src/finiteVolume/lnInclude/fvPatchFieldNew.C at line 148. FOAM exiting thanks in advance. FoamFile { version 2.0; format ascii; class volScalarField; object p_rgh; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [1 -1 -2 0 0 0 0]; internalField uniform 0; boundaryField { inlet { type fixedFluxPressure; value uniform 0; } outlet { type fixedFluxPressure; value uniform 0; } ground { type fixedFluxPressure; value uniform 0; } walls { type fixedFluxPressure; value uniform 0; } atmosphere { type totalPressure; p0 uniform 0; U U; phi phi; rho rho; psi none; gamma 1; value uniform 0; } floatingObject { type fixedFluxPressure; } overset { type overset; } sides { pathcType overset; type fixedValue; } } // ************************************************** *********************** // |
October 1, 2019, 09:02 |
Piotr Ładyński
Rep Power: 9 |
November 21, 2019, 16:02 |
Bagya Vivekanandhan
Rep Power: 7 |
Thanks for your time and reply @piotr.mecht. I got it solved. yes, it was the PatchType error.
p_gh ? |
non reflective boundary conditions for incompresible flow | Pascal_doran | OpenFOAM Programming & Development | 16 | August 25, 2015 06:35 |
Implementation of boundary conditions for FVM | Tom | Main CFD Forum | 7 | August 26, 2014 06:58 |
Question about heat transfer coefficient setting for CFX | Anna Tian | CFX | 1 | June 16, 2013 07:28 |
Update boundary conditions calculated by an external program | CedricVH | OpenFOAM | 2 | January 15, 2010 12:55 |
Boundary conditions? | Tom | Main CFD Forum | 0 | November 5, 2002 02:54 |
