Strange result for 2D foil (simpleFoam & pimpleFoam) |
September 29, 2019, 12:15 |
Uncontinous pressure distribution near high aspect ratio mesh
Youjiang Wang
Rep Power: 11 |
Hallo, my colleagues,
I just begin to use openFoam and want to test it on a 2D foil. The Reynolds number is 8e+7. The mesh is generated using blockMesh. kOmegaSST is used as the turbulence model. The settings are adjusted according to several tutorials. Firstly i calculated NACA0012 with sharp edge. simpleFoam and SIMPLEC are used. The obtained Cl and Cd seem to be OK, but the vorticity distribution is quite strange, especially near the block interfaces. The mesh figure is attached. Also the yPlus has a jump at the middle chord position, where there is also a block interface. Does anyone have any idea for it naca0012_mesh.jpg Screenshot_20190929_164403.jpg naca0012_yPlus.png Besides that, I have also calculated a foil with cutted trailing edge. Then the flow near the trailing edge is more strange. Even the pressure distribution is wrong. I carried pimpleFoam simulations after the simpleFoam, the results are improved but still strange. Foil2_TePressure.jpg Foil2_Vorticity.jpg Below are the control, fvScheme and fvSolution dictionaries. Code:
FoamFile { version 2.0; format ascii; class dictionary; location "system"; object controlDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // application simpleFoam; //startFrom startTime; startTime 0; stopAt endTime; endTime 3000; deltaT 3.5; writeControl timeStep; writeInterval 100; purgeWrite 0; writeFormat ascii; writePrecision 6; writeCompression off; timeFormat general; timePrecision 6; runTimeModifiable true; functions { vorticity1 { type vorticity; libs ("libfieldFunctionObjects.so"); writeControl writeTime; } yPlus1 { type yPlus; libs ("libfieldFunctionObjects.so"); writeControl writeTime; } forcesCoeffs1 { type forceCoeffs; libs ("libforces.so"); log yes; writeFields no; writeControl timeStep; writeInterval 1; patches (foil); CofR (0 0 0); rho rhoInf; magUInf 80; lRef 1; Aref 1; rhoInf 1; porosity no; dragDir (1 0 0); liftDir (0 1 0); sideDir (0 0 1); rollAxis (1 0 0); pitchAxis (0 0 1); yawAxis (0 1 0); binData { nBin 2; direction (1 0 0); cumulative yes; } } } Code:
FoamFile { version 2.0; format ascii; class dictionary; location "system"; object fvSchemes; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // ddtSchemes { default steadyState; } gradSchemes { default Gauss linear; } divSchemes { default none; div(phi,U) bounded Gauss linearUpwind grad(U); div(phi,k) bounded Gauss limitedLinear 1; // linearUpwind grad(k); div(phi,epsilon) bounded Gauss limitedLinear 1; // linearUpwind grad(epsilon); div(phi,omega) bounded Gauss limitedLinear 1; // linearUpwind grad(omega); div(phi,nuTilda) bounded Gauss linearUpwind grad(nuTilda); div((nuEff*dev2(T(grad(U))))) Gauss linear; } laplacianSchemes { default Gauss linear corrected; } interpolationSchemes { default linear; } snGradSchemes { default corrected; } wallDist { method meshWave; } Code:
FoamFile { version 2.0; format ascii; class dictionary; location "system"; object fvSolution; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // solvers { p { solver GAMG; tolerance 1e-06; relTol 0.1; smoother GaussSeidel; } "(U|k|epsilon|R|nuTilda)" { solver smoothSolver; smoother GaussSeidel; nSweeps 2; tolerance 1e-08; relTol 0.01; } omega { solver PBiCGStab; preconditioner DILU; tolerance 1e-10; relTol 0.1; } } SIMPLE { nNonOrthogonalCorrectors 2; consistent yes; residualControl { p 1e-8; U 1e-8; nuTilda 1e-8; k 1e-8; omega 1e-8; epsilon 1e-8; } } relaxationFactors { fields { p 1.0; } equations { U 0.7; nuTilda 0.9; k 0.7; omega 0.7; epsilon 0.8; } } Last edited by wyj216; October 2, 2019 at 03:39. Reason: more clear |
September 29, 2019, 12:21 |
Youjiang Wang
Rep Power: 11 |
October 1, 2019, 04:13 |
Youjiang Wang
Rep Power: 11 |
For the problem near the trailing edge, someone told me that it may be caused by the high aspect ratio cells near the trailing edge.
But I have carried out the simulation with the same mesh using CFX, also kOmegaSST turbulence model and high order advection scheme (I do not know exactly what it is). The result looks much better. Does anyone have similar experience and any explainations? PS. The problem near the block interfaces show up also in CFX, but much weaker than in openFoam. 6600_CurlZ_TE.jpg 6600_Pressure_TE.jpg |
simpleFoam + cyclone device. Poor result. | rightnow | OpenFOAM Running, Solving & CFD | 5 | March 5, 2012 07:38 |
Strange Result for Versteeg Testcase (2D, convection only, steady state) | caramelo | OpenFOAM Running, Solving & CFD | 4 | August 17, 2011 18:55 |
Strange Result of turboPassageRotating tutorial. | Ohbuchi | OpenFOAM Running, Solving & CFD | 0 | July 27, 2011 22:06 |
the result of pitzDaily using simpleFoam and pisoFoam | Kr_kim | OpenFOAM Running, Solving & CFD | 1 | March 16, 2010 14:38 |
SimpleFoam result for turbFoam initialisation | philippose | OpenFOAM Running, Solving & CFD | 0 | November 26, 2006 11:24 |
