isothermal boundary condition with compressible two-phase flow |
September 25, 2019, 05:43 |
Mat
Rep Power: 14 |
Dear Foamers,
I am working with a two-phase flow problem involving relatively high pressure and temperature, and for that I am using compressibleInterFoam When using adiabatic boundary conditions for the wall of my domain, I can obtain physical results. However, when using isothermal conditions, the simulation does not converge. I have attached images of the temperature and velocity fields near the wall, in a region of pure gas. The temperature gradient between the cold wall and the warm gas is creating fluid motion towards the wall. Eventually this field becomes too high and deteriorates the other physical variables, generating finally high temperature in the first cell layers. I understand that the temperature gradient creates fluid motion, but this is unrealistic and especially considering the no-slip wall condition for the velocity. The thermophysical properties for the gas are: Code:
thermoType { type heRhoThermo; mixture pureMixture; transport sutherland; thermo hConst; equationOfState PengRobinsonGas; specie specie; energy sensibleEnthalpy; } I have tried to use an externalWallHeatFluxTemperature boundary condition for the temperature, which is less "strong" than the isothermal one. Although the computation does converge in this case, results are unrealistic as way too much heat is transferred out of the gas. Regards, |
November 22, 2019, 12:54 |
Mat
Rep Power: 14 |
No one has an idea regarding this issue ? |
CFD analaysis of Pelton turbine | amodpanthee | CFX | 31 | April 19, 2018 19:02 |
Wrong flow in ratating domain problem | Sanyo | CFX | 17 | August 15, 2015 07:20 |
How to set the velocity inlet boundary condition in the compressible flow? | lienien | FLUENT | 2 | March 11, 2013 09:25 |
3 phase flow (wall boundary condition) | Mohsin | FLUENT | 1 | October 6, 2011 08:22 |
Convective Heat Transfer - Heat Exchanger | Mark | CFX | 6 | November 15, 2004 16:55 |
