Double Wedge SonicDyMFoam strange lines
Old   September 23, 2019, 11:28
Default Double Wedge SonicDyMFoam strange lines
Dustin
dustinb is on a distinguished road
Hi everyone,
i try to simulate supersonic flow on a double Wedge with sonicDyMFoam. The Solution has strange lines at the leading edge. Does anyone know why there are these lines and why is the shock at the tailing edge cloudy ?
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "system";
    object      fvSolution;
solvers
    "p.*"
        solver          smoothSolver;
        smoother        symGaussSeidel;
        tolerance       1e-06;
        relTol          0;
    "(U|e).*"
        $p;
        tolerance       1e-05;
        relTol          0;
    "rho.*"
        solver          PCG;
        preconditioner  DIC;
        tolerance       1e-05;
        relTol          0;
PIMPLE
    nOuterCorrectors 2;
    nCorrectors      2;
    nNonOrthogonalCorrectors 1;
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "system";
    object      fvSchemes;
ddtSchemes
    default         Euler;
gradSchemes
    default         Gauss linear;
divSchemes
    default         none;
    div(phi,U)      Gauss upwind;
    div(phid,p)     Gauss limitedLinear 1;
    div(phi,e)      Gauss limitedLinear 1;
    div(phi,K)      Gauss limitedLinear 1;
    div(phiv,p)     Gauss limitedLinear 1;
    div(((rho*nuEff)*dev2(T(grad(U))))) Gauss linear;
laplacianSchemes
    default         Gauss linear corrected;
interpolationSchemes
    default         linear;
snGradSchemes
    default         corrected;
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "system";
    object      controlDict;
application     sonicDyMFoam;
startFrom       latestTime;
startTime       0;
stopAt          endTime;
endTime         0.001;
deltaT          0.0000001;
writeControl    adjustableRunTime;
writeInterval   0.0000005;
purgeWrite      0;
writeFormat     ascii;
writePrecision  6;
writeCompression off;
timeFormat      general;
timePrecision   6;
runTimeModifiable true;
adjustTimeStep  yes;
maxCo           0.3;
functions
    libs ("libfieldFunctionObjects.so");
    Ma
        type            MachNo;
        executeControl  writeTime;
        writeControl    writeTime;
Cheers,
Dustin
dustinb is offline   Reply With Quote
[Tutorials] Tutorial of how to plot residuals ! wolle1982 OpenFOAM Community Contributions 172 December 6, 2024 07:20
[snappyHexMesh] Error snappyhexmesh - Multiple outside loops avinashjagdale OpenFOAM Meshing & Mesh Conversion 53 March 8, 2019 10:42
fvOptions npatricia OpenFOAM 6 May 23, 2018 06:21
[TurboGrid] Hub&Shround part Strange lines are created. ByeongLae ANSYS Meshing & Geometry 0 May 8, 2014 04:45
Plotting Residuals ata OpenFOAM 12 July 8, 2011 03:50
