Steady state conjugate heat transfer analysis in openfoam version 7 |
September 22, 2019, 07:42 |
Steady state conjugate heat transfer analysis in openfoam version 5
Srikar
Rep Power: 7 |
Hi, I am running "chtMultiRegionSimpleFoam" solver and irrespective of the case, meshing and number of iterations, I get the note:
"Regions not converged after XXXXX iterations". I even tried decreasing the tolerance to 0.1, still the note comes Can anyone tell me what could have been done better? I am performing simulation for steadystate, laminar and incompressible flow. Last edited by srikarg; September 22, 2019 at 08:46. |
September 22, 2019, 08:08 |
Herpes Free Engineer
Rep Power: 13 |
The OpenFOAM community is the biggest contributor to OpenFOAM: User guide/Wiki-1/Wiki-2/Code guide/Code Wiki/Journal Nilsson/Guerrero/Holzinger/Holzmann/Nagy/Santos/Nozaki/Jasak/Primer Governance Bugs/Features: OpenFOAM (ESI-OpenCFD-Trademark) Bugs/Features: FOAM-Extend (Wikki-FSB) Bugs: OpenFOAM.org How to create a MWE New: Forkable OpenFOAM mirror |
September 22, 2019, 11:31 |
#3 | |
Ali Shayegh
Rep Power: 11 |
September 22, 2019, 11:55 |
PFA my case in the link attached
#4 | |
Srikar
Rep Power: 7 |
Please find the case through the link https://drive.google.com/drive/folde...8N?usp=sharing |
September 27, 2019, 10:38 |
#5 | |
Ali Shayegh
Rep Power: 11 |
So it can not be run. |
September 27, 2019, 13:31 |
#6 | |
Ali Shayegh
Rep Power: 11 |
September 28, 2019, 02:36 |
Openfoam version 5
Srikar
Rep Power: 7 |
I use Openfoam version 5. Kindly find the updated case at
https://drive.google.com/drive/folde...dh?usp=sharing |
October 11, 2019, 04:06 |
#8 | |
Ali Shayegh
Rep Power: 11 |
As I use openfom > 6 and this solver is deprecated hereafter, I can not reproduce your example until I have enough time to install version 5. Sorry for late. Best, Ali |
October 11, 2019, 07:58 |
#9 | |
Ali Shayegh
Rep Power: 11 |
Best, Ali |
chtmultiregionsimpefoam, heat tranfer, laminar, openfoam v5.0, steady state |
Steady state conjugate heat transfer analysis in openfoam version 7 | srikarg | OpenFOAM Running, Solving & CFD | 3 | September 18, 2019 00:19 |
[mesh manipulation] Conjugate Heat Transfer Fluent Mesh Conversion to OpenFOAM | Lancia037 | OpenFOAM Meshing & Mesh Conversion | 2 | August 22, 2019 09:11 |
OpenFOAM v3.0+ ?? | SBusch | OpenFOAM | 22 | December 26, 2016 14:24 |
Simple piston movement in cylinder- fluid models | arun1994 | CFX | 4 | July 8, 2016 02:54 |
Conjugate Heat Transfer analysis using FLUENT | Ravi Kiran | FLUENT | 0 | February 16, 2006 04:39 |
