2D Sloshing Analysis Gives Error in blueCFD
Old   September 18, 2019, 08:59
Question 2D Sloshing Analysis Gives Error in blueCFD
Emre
ordinary is on a distinguished road
Hello foamers,
I encountered an error when I tried to run a 2d sloshing simulation. I send the case in the attachment. And here I post the error after I type interDyMFoam below:
$ interDyMFoam.exe
| \\ / O peration | Version: 5.x |
| \\ / A nd | Web: www.OpenFOAM.org |
| \\/ M anipulation | |
/* Windows 32 and 64 bit porting by blueCAPE: http://www.bluecape.com.pt *\
| Based on Windows porting (2.0.x v4) by Symscape: http://www.symscape.com |
Build : 5.x-963176928289
Exec : C:/PROGRA~1/BLUECF~1/OpenFOAM-5.x/platforms/mingw_w64GccDPInt32Opt/bin/interDyMFoam.exe
Date : Sep 18 2019
Time : 14:50:12
Host : "me"
PID : 12584
I/O : uncollated
Case : C:/Program Files/blueCFD-Core-2017/msys64/home/ofuser/emre/2DSimpleCase
nProcs : 1
SigFpe : Enabling floating point exception trapping (FOAM_SIGFPE).
fileModificationChecking : Monitoring run-time modified files using timeStampMaster (fileModificationSkew 10)
allowSystemOperations : Allowing user-supplied system call operations
Create time
Create mesh for time = 0
Selecting dynamicFvMesh dynamicMotionSolverFvMesh
Selecting motion solver: solidBody
Selecting solid-body motion function SDA
Applying solid body motion to entire mesh
PIMPLE: Operating solver in PISO mode
Reading field p_rgh
Reading field U
Reading transportProperties
Selecting incompressible transport model Newtonian
Selecting turbulence model type laminar
Selecting laminar stress model Stokes
Reading g
Reading hRef
Calculating field g.h
No MRF models present
No finite volume options present
GAMGPCG: Solving for pcorr, Initial residual = 0, Final residual = 0, No Iterations 0
time step continuity errors : sum local = 0, global = 0, cumulative = 0
Reading/calculating face velocity Uf
Courant Number mean: 0 max: 0
Starting time loop
Interface Courant Number mean: 0 max: 0
deltaT = 0.00238095
Time = 0.00238095
PIMPLE: iteration 1
Execution time for mesh.update() = 0.014 s
MULES: Solving for alpha.water
Phase-1 volume fraction = 0.5 Min(alpha.water) = 0 Max(alpha.water) = 1
GAMG: Solving for p_rgh, Initial residual = 1, Final residual = 0.00873178, No Iterations 6
time step continuity errors : sum local = 2.32114e-008, global = 4.50098e-016, cumulative = 4.50098e-016
GAMGPCG: Solving for p_rgh, Initial residual = 9.63745e-005, Final residual = 3.17026e-010, No Iterations 6
time step continuity errors : sum local = 1.45552e-012, global = 4.50098e-016, cumulative = 9.00196e-016
ExecutionTime = 0.211 s ClockTime = 0 s
Courant Number mean: 5.24916e-010 max: 1.11254e-007
deltaT = 0.00278912
Time = 0.00517007
PIMPLE: iteration 1
Phase-1 volume fraction = 0.5 Min(alpha.water) = -3.79163e-053 Max(alpha.water) = 1
GAMG: Solving for p_rgh, Initial residual = 0.0104674, Final residual = 6.0087e-005, No Iterations 4
time step continuity errors : sum local = 2.11834e-008, global = 2.58885e-017, cumulative = 9.26084e-016
GAMGPCG: Solving for p_rgh, Initial residual = 7.16276e-005, Final residual = 3.34913e-010, No Iterations 6
time step continuity errors : sum local = 1.88654e-012, global = 2.58885e-017, cumulative = 9.51973e-016
ExecutionTime = 0.289 s ClockTime = 0 s
Courant Number mean: 7.53222e-010 max: 1.79939e-007
deltaT = 0.00327
Time = 0.00844007
PIMPLE: iteration 1
Phase-1 volume fraction = 0.5 Min(alpha.water) = -1.13801e-050 Max(alpha.water) = 1
Phase-1 volume fraction = 0.5 Min(alpha.water) = -2.70683e-051 Max(alpha.water) = 1
GAMG: Solving for p_rgh, Initial residual = 0.0122437, Final residual = 8.8839e-005, No Iterations 3
time step continuity errors : sum local = 3.97872e-008, global = -5.48999e-016, cumulative = 4.02974e-016
GAMGPCG: Solving for p_rgh, Initial residual = 0.000110277, Final residual = 5.3707e-010, No Iterations 6
time step continuity errors : sum local = 2.72597e-012, global = -5.48999e-016, cumulative = -1.46025e-016
ExecutionTime = 0.364 s ClockTime = 1 s
Courant Number mean: 1.09986e-009 max: 2.7167e-007
deltaT = 0.003815
Time = 0.0122551
PIMPLE: iteration 1
Phase-1 volume fraction = 0.5 Min(alpha.water) = -9.34524e-051 Max(alpha.water) = 1
GAMG: Solving for p_rgh, Initial residual = 0.0156236, Final residual = 8.36713e-005, No Iterations 3
time step continuity errors : sum local = 4.42918e-008, global = 1.43162e-016, cumulative = -2.8635e-018
GAMGPCG: Solving for p_rgh, Initial residual = 0.000100896, Final residual = 5.29966e-010, No Iterations 6
time step continuity errors : sum local = 3.49302e-012, global = 1.43162e-016, cumulative = 1.40298e-016
ExecutionTime = 0.441 s ClockTime = 1 s
Courant Number mean: 1.5682e-009 max: 3.91461e-007
deltaT = 0.00438725
Time = 0.0166423
PIMPLE: iteration 1
Phase-1 volume fraction = 0.5 Min(alpha.water) = -6.404e-050 Max(alpha.water) = 1
Phase-1 volume fraction = 0.5 Min(alpha.water) = -1.22147e-049 Max(alpha.water) = 1
GAMG: Solving for p_rgh, Initial residual = 0.0195332, Final residual = 0.000155164, No Iterations 2
Generating stack trace...
Backtrace:
ZN10StackTraceC1Ev [0x705c1465+0x25]
module: C:\PROGRA~1\BLUECF~1\ThirdParty-5.x\platforms\mingw_w64GccDPInt32\lib\libstack_tra ce.dll
ZN4Foam5error10printStackERNS_7OstreamE [0x1141c88+0x218]
module: C:\PROGRA~1\BLUECF~1\OpenFOAM-5.x\platforms\mingw_w64GccDPInt32Opt\lib\libOpenFO AM.dll
ZN4Foam6sigFpe13sigFpeHandlerEi [0x1142af3+0x33]
(No symbol) [0x405a1d]
module: C:\PROGRA~1\BLUECF~1\OpenFOAM-5.x\platforms\mingw_w64GccDPInt32Opt\bin\interDyMF oam.exe
_C_specific_handler [0x7ffc933c7c58+0x98]
module: C:\Windows\System32\msvcrt.dll
0_chkstk [0x7ffc93a2f7dd+0x11d]
module: C:\Windows\SYSTEM32\ntdll.dll
RtlWalkFrameChain [0x7ffc9399d856+0x13f6]
KiUserExceptionDispatcher [0x7ffc93a2e70e+0x2e]
ZN4Foam6divideERNS_5FieldINS_6VectorIdEEEERKNS_5UL istIS2_EERKNS_6TensorIdEE [0x111934b+0x84b]
(No symbol) [0x444329]
(No symbol) [0x440d86]
(No symbol) [0x440ad5]
(No symbol) [0x4a673e]
(No symbol) [0x4013f7]
(No symbol) [0x40152b]
BaseThreadInitThunk [0x7ffc91484034+0x14]
module: C:\Windows\System32\KERNEL32.DLL
RtlUserThreadStart [0x7ffc93a03691+0x21]
Does anybody know what does this mean?
Regards,
Emre
ordinary is offline   Reply With Quote
bluecfd, openfaom, slosh
ANSYS coupled sloshing and ship motion analysis kites FLUENT 1 April 3, 2020 10:25
Interfaces during sloshing analysis Aashi171185 CFX 1 February 23, 2019 04:24
Tabk sloshing analysis inside barge subjected to beam seas Dimo STAR-CCM+ 1 May 1, 2018 05:48
Explicit dynamics results for initial condition to another explicit dynamics analysis KOI Structural Mechanics 0 March 2, 2018 05:16
ANSYS WORKBENCH Transfer result of one analysis to a new analysis as preload ingjuanm90 ANSYS 0 July 26, 2016 15:04
