simpleFoam-MRF to rhoSimpleFoam-MRF strange results
Old   September 17, 2019, 11:00
Default simpleFoam-MRF to rhoSimpleFoam-MRF strange results
Kmeti Rao
Krao is on a distinguished road
Hello Foamers,
I am simulating a propeller which I have described in the following link One half propeller simulation with MRFSimpleFoam crashing. Thanks to all users who have helped me to come to this point with the simulation, starting from full propeller configuration to half propeller configuration, with so many inputs in-between.
The results obtained so far are satisfactory and now I am continuing this simulation by considering the compressible effects, as I am willing to increase the motor rpm in future.
A brief introduction with the setup: I am using OpenFOAM 6 from openfoam.org, I have prepared the initial setup of incompressible steady state simulation with MRF, using different tutorials available(pimple --> propeller and simple --> mixer vessel) and inputs from the forum. Now I have switched to rhoSimpleFoam by editing the p file and adding alphaT and T to the latest time step.
The following are my results obtained during the simulations involving simpleFoam and rhoSimpleFoam, as it can be seen, both the results are almost similar except the highlighted one. The force in x-direction has been drastically increased, while the area of interest i.e., the thrust and torque in the z-direction are satisfactory. It would be great if anyone explains why this strange behavior could happen. Also let me know if I need to provide more information regarding setup such as ICs and BCs, if it is a complex error.
sum of forces:
pressure : (0.291062 3.70328 22.952)
viscous : (0.000151899 0.251535 -0.0315308)
porous : (0 0 0)
sum of moments:
pressure : (-0.0905238 5.44235 -0.793572)
viscous : (-0.00136577 -0.00609683 -0.0587384)
porous : (0 0 0)
After initializing the compressible simulation by reconstructing the last step of the in-compressible simulation, and the results obtained are,
sum of forces:
pressure : (322.763 3.51019 21.65)
viscous : (0.000227725 0.296663 -0.04378)
porous : (0 0 0)
sum of moments:
pressure : (-0.0807525 5.15715 -0.74892)
viscous : (-0.00126643 -0.00468166 -0.0614343)
porous : (0 0 0)
Thank you all in advance,
Krao
Krao is offline   Reply With Quote
Old   August 19, 2021, 11:11
Gabriel Felix
gabrielfelix is on a distinguished road
I'm also trying to run my propeller in compressible flow. Can you attach your 0, constant and system folders? I'm setting my files according to the rhoSimpleFoam tutorials, however I'm not succeding on running my case. There are many errors.
gabrielfelix is offline   Reply With Quote
Old   August 20, 2021, 15:55
Fouch is on a distinguished road
Hello guys,
I am working with MRF rhoSimpleFoam also.
I finally get correct results after many try.
Could share :
- pressure / velocity residual graph ?
- 0 / fvSolution / fvSchemes ?
- checkMesh result ?
Cheers !
Fouch is offline   Reply With Quote
compressible flow, forces and force coeff., propeller, rhosimplefoam
simpleFoam + MRF properties: FATAL ERROR: not implemented student666 OpenFOAM Running, Solving & CFD 3 April 11, 2021 04:11
rhoSimpleFoam MRF cyclicACMI centrifugal compressor dcook OpenFOAM Running, Solving & CFD 3 February 5, 2021 11:13
simpleFoam - wrong results? Zibi OpenFOAM Running, Solving & CFD 26 October 9, 2020 13:21
SRFSimpleFoam vs SimpleFoam (MRF) oscar_urri OpenFOAM Running, Solving & CFD 9 November 13, 2018 18:18
Simulation of Radial Fan with simpleFoam MRF nash OpenFOAM Running, Solving & CFD 2 November 5, 2015 11:12
