SimpleFoam Laminar Pipe Flow Pressure Drop Error
Old   September 13, 2019, 09:10
Default SimpleFoam Laminar Pipe Flow Pressure Drop Error
Xiaolong Liu
xiaolong is on a distinguished road
Hello Foamers,
I am new to openfoam. I am trying to simulate a laminar pipe flow by using simpleFoam and compare the pressure drop with the analytical solution. However, I found a quite consistent about 11% pressure drop error by adjusting the inlet velocity (Re=500, 1000, 1500, 2000)
Below are the parameters I used for this simulation
Pipe length (L): 0.5m
Pipe diameter (D): 0.015m
Dynamic viscosity (mu): 8.9e-4 N/m-s
Density (rho): 997 kg/m^3
Max value of parabolic velocities:
(1) 5.96e-2 m/s(Re=500); (2) 1.19e-1 m/s (Re=1000); (3) 1.78e-1 m/s (Re=1500); (4) 2.38e-1 m/s (Re=2000).
Boundary conditions:
p:
Inlet: zeroGradient;
Outlet: fixedValue uniform 0;
Wall: zeroGradient;
U:
Inlet: parabolic velocity (I tried fixedvalue uniform inlet velocity as well without measuring in the entry length region, the same problem);
Outlet: zeroGradient;
Wall: fixedValue uniform (0 0 0);
I also compared simulation results with Fluent, as shown in the figure below:
https://www.dropbox.com/s/22xv8hlwuv...luent.png?dl=0
I have tried (1) refining the mesh in different levels; (2) adjusting the gradient scheme to leastsquares method; (3) importing the mesh developed in ANSYS for Fluent simulation. None of these can change the results.
Since this is a very simple case, I believe simpleFoam should be able to provide accurate prediction on the pressure drop. However, I just can not get it.
I really appreciate if anyone can help to point out what the problem is.
Please find my code in the following link:
https://www.dropbox.com/s/w91ak3klx3..._flow.zip?dl=0
Thanks,
Xiaolong
xiaolong is offline   Reply With Quote
Old   September 16, 2019, 09:26
Xiaolong Liu
Anyone has some insight in this?
Old   September 16, 2019, 10:57
Bloerb will become famous soon enough
Your viscosity in transportProperties ("1e-06; //water")
does not match what you specified
Bloerb is offline   Reply With Quote
Old   September 16, 2019, 11:37
Xiaolong Liu
Hi Bloerb,
Thank you very much. I didn't realize I messed up with my data. Now it's matching.
Best,
Xiaolong
DPM udf error haghshenasfard FLUENT 0 April 13, 2016 07:35
Compile problem ivanyao OpenFOAM Running, Solving & CFD 1 October 12, 2012 10:31
Ansys Fluent 13.0 UDF compilation problem in Window XP (32 bit) Yogini Fluent UDF and Scheme Programming 7 October 3, 2012 08:24
ParaView for OF-1.6-ext Chrisi1984 OpenFOAM Installation 0 December 31, 2010 07:42
CGNS lib and Fortran compiler manaliac Main CFD Forum 2 November 29, 2010 07:25
