How to solve Evaporation based on Condition ~ if-else loop |
September 13, 2019, 02:35 |
#1 | ||
Hello Foamers,
This evaporation problem is a part of work in my main problem. The problem is simple, a rectangular 1D channel is considered where right end is symmetry, left end is with the temperature of 373K, other faces are empty (1D problem). 10% of liquid (moisture) is considered inside the channel. The liquid is evaporated based on the condition as follows: Quote:
I'm hereby attaching the solver (OF211). In this solver, under TEqn.H, I solved a if-else loop based on the above condition. Quote:
If someone have any ideas about it, kindly do share. It will be helpful. Thank you |
periodic boundary condition in a loop flow | dinesh | Main CFD Forum | 0 | March 25, 2017 02:33 |
Framework for moving mesh based on 2D-computation as a boundary condition | Arnoldinho | OpenFOAM Running, Solving & CFD | 0 | May 17, 2011 13:48 |
can fluent(multiphase model) solve evaporation | prasanth | FLUENT | 9 | June 16, 2010 07:27 |
[CAD formats] my stl surface is seen as just a line | rcastilla | OpenFOAM Meshing & Mesh Conversion | 2 | January 6, 2010 02:30 |
CFX Solver : Sudden crash | Hervé | CFX | 2 | June 16, 2008 07:40 |
