Setting constantAlphaContactAngle in interMixingFoam |
September 11, 2019, 14:59 |
Chan Kwok Hoe
Rep Power: 7 |
Dear all,
I'm new to OpenFOAM, using OpenFOAM 7. I've managed to simulate a simple drop of water on a flat surface using the interFoam function. I moved on to trying the interMixingFoam function as I needed to simulate some mixing of liquids on a hydrophobic flat surface. However, I was unable to set the contact angle. The simulation runs fine though. I placed the following inside the boundaryField for alpha.water.orig Code:
walls { type constantAlphaContactAngle; theta0 157.5; limit gradient; value uniform 0; } Am I doing something wrong here? |
September 15, 2019, 05:43 |
Chan Kwok Hoe
Rep Power: 7 |
Just realised what went wrong. While I set the theta0 for the water, the theta0 for air was set to zeroGradient. As a result, the theta0 for the water phase was probably overwritten.
In order to get the results I needed, the theta0 for the air phase was also explicitly defined, similarly to the water phase (though 180-waterContactAngle) |
constantalphacontactangle, intermixingfoam |
Fluent Parallelization Problem After AC Power Dropped | pawl | Hardware | 5 | November 13, 2016 06:08 |
using chemkin | JMDag2004 | OpenFOAM Pre-Processing | 2 | March 8, 2016 22:38 |
[snappyHexMesh] determining displacement for added points | CFDnewbie147 | OpenFOAM Meshing & Mesh Conversion | 1 | October 22, 2013 09:53 |
Cells with t below lower limit | Purushothama | Siemens | 2 | May 31, 2010 21:58 |
Warning 097- | AB | Siemens | 6 | November 15, 2004 04:41 |
