Bubble is not increasing in size in Nucleate boiling |
December 21, 2020, 00:07 |
#41 |
Bali
Rep Power: 8 |
December 22, 2020, 03:00 |
#42 |
M Naarendharan
Rep Power: 6 |
Thank you for the reply, I will try your suggestion and will get back to you. Thanking you, M Naarendharan |
November 17, 2021, 15:55 |
#43 |
jack
Rep Power: 8 |
hi
could you please tell which phase change model did you use? what was your boundary conditions? I would appreciate if you upload your case file. many thanks in advance |
bubble, nucleate boiling |
Why pressure is increasing when Degassing BC is used for a pool boiling case? | soumitra2102 | CFX | 5 | August 4, 2020 07:21 |
TwoPhaseEulerFoam - Bubble diameter size Problem | BlnPhoenix | OpenFOAM Running, Solving & CFD | 8 | September 17, 2019 16:59 |
How to make UDFs for Nucleate Pool Boiling Simulation? | SIKJAE | Fluent UDF and Scheme Programming | 1 | August 4, 2018 08:07 |
OpenFOAM UpdateCoeffs Nucleate Wall Boiling | suneth.warna | OpenFOAM Programming & Development | 0 | July 31, 2016 18:42 |
Flow boiling & bubble formation | Venkat | CFX | 1 | July 23, 2009 10:20 |
