FOAM-extend's interFoam giving different results compared to OpenFOAM's
Old   August 27, 2019, 05:24
Default FOAM-extend's interFoam giving different results compared to OpenFOAM's
Santiago Lopez Castano
Santiago is on a distinguished road
Hi all,
I've been struggling a bit to get the right results using Extend's version of interFoam. In general, I cannot get the right discharge of a pipe flow driven by gravity
I have prepared a very simple version of my problem: pipe flow between two tanks. The pipe diameter is 1 m, lenght is ~72 m, the upstream head is 3.561 m and the downstream head is of 3.4 m. Assuming a smooth pipe, by using Bernoulli + Colebrook-White one gets that the discharge is around 1.2 cu.m/s.
If I go and set the case in FOAM-extend, I get a discharge of ~206 lt/s (!!), as shown in the figure below.
https://imgur.com/vXPxaNF
Running the exact same case (same BCs) in OpenFOAM v.4, gives me a discharge of 1.05 cu.m/s. For this I don't have a figure 'cause I couldn't make codeStreams to work in this version (see attached files)
I have tarred the cases I ran using FOAM-extend, and the one of OpenFOAM. You can download them here:
https://we.tl/t-SCwqNyZG5u
I would really appreciate some input on this, since I cannot see any noticeable difference neither between the algorithms, except on how the pressure is called (pd vs. p_rgh), nor on the cases' setup.
Thanks
Santiago is offline   Reply With Quote
[Other] refineWallLayer Error Yuby OpenFOAM Meshing & Mesh Conversion 2 November 11, 2021 12:04
[CGNS] CGNS converters available mbeaudoin OpenFOAM Meshing & Mesh Conversion 137 December 14, 2018 05:20
problem during mpi in server: expected Scalar, found on line 0 the word 'nan' muth OpenFOAM Running, Solving & CFD 3 August 27, 2018 05:18
Problem with rhoSimpleFoam matteo_gautero OpenFOAM Running, Solving & CFD 0 February 28, 2008 07:51
[blockMesh] Axisymmetrical mesh Rasmus Gjesing (Gjesing) OpenFOAM Meshing & Mesh Conversion 10 April 2, 2007 15:00
