multiphaseEulerFoam convergence problems
Old   August 26, 2019, 03:16
Default multiphaseEulerFoam convergence problems
Stefanie Wolf
Stefanie.S.W. is on a distinguished road
i am running a case with multiphaseEulerFoam (V6), where oil and water mixed with a surfactant collapse together in a cylinder at time 0. (based on the dam break tutorial)
It runs super stable, but when oil and the water solution are seperated again they start oscillating in a wave motion. As if a force from outside is applied. This is not the case, nothing is mooving, the only driving force is gravity.
I got the tip that the therms for pressure and velocity might not converge, so I tried to improve fvScheme and fvSolution. I got help from this great presentation: http://www.wolfdynamics.com/wiki/fvm_crash_intro.pdf
But now unfortunately my simulation crashes within 0.15 sek.
(all simulations run decomposed, 6 cores, simple decomposition)
Do you know which settings in fvSchemes and fvSolutions are wrong?
Can you recommend 2nd Order schemes to me?
Do you have additional tips for me?
(dicts are following)
Thank you a lot for your help!! Unfortunately I can not share the whole geometry (46926 cells, no errors). I hope that it is enough information! Please let me know if I forgot anything.
fvScheme: default settings are in the comments
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "system";
    object      fvSchemes;
ddtSchemes
    default   Euler;
gradSchemes
   default     cellLimited Gauss linear 1;
   grad(U)     cellLimited Gauss linear 1;//default         Gauss linear;
divSchemes
    "div\(phi,alpha.*\)"    Gauss linear;//vanLeer;
    "div\(phir,alpha.*,alpha.*\)"   Gauss linear;//vanLeer;
    "div\(alphaPhi.*,U.*\)" Gauss limitedLinearV 1;
    div(Rc)                 Gauss linear;
    "div\(phi.*,U.*\)"      Gauss limitedLinearV 1;
    //div(alphaPhi.water,U.water)
laplacianSchemes
    default         Gauss linear limited 1;//corrected;
interpolationSchemes
    default         linear;
snGradSchemes
    default         limited 1;//corrected;
//fluxRequired (ALWAYS DEACTIVATED)
//    default         no;
//    p;
//    pcorr;
fvSolutions
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "system";
    object      fvSolution;
solvers
    "alpha.*"
        nAlphaSubCycles 3;
    p_rgh
        solver          GAMG;
        tolerance       1e-7;
        relTol          0.01; // 0.05;
        smoother       GaussSeidel;
    p_rghFinal
        solver          PCG;
        preconditioner
            preconditioner  GAMG;
            tolerance       1e-7;
            relTol          0;
            nVcycles        2;
        tolerance       1e-7;
        relTol          0;
        maxIter         20;
    "pcorr.*"
        $p_rghFinal;
        tolerance       1e-5;
        relTol          0;
    U
        solver          smoothSolver;
        tolerance       1e-8;
        relTol          0;//0.1;
        nSweeps         1;
    "U.*" //22.09.2019
        tolerance       1e-8;
        relTol          0;//0.1;
        nSweeps         1;
    UFinal
        $U;
        tolerance       1e-7;
        relTol          0;
PIMPLE
    nCorrectors              3;
    nNonOrthogonalCorrectors 0;
relaxationFactors
    "U.*"           1;
Transport Properties:
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "constant";
    object      transportProperties;
phases
     water
         nu         1e-06;
         kappa      1e-06;
         Cp         4195;
         rho        1000;
         diameterModel constant;
         constantCoeffs
             d               5e-4; //13.08.2019 1e-3
     oil
         nu         9.6e-06;
         kappa      1e-06;
         Cp         4195;
         rho        805;
         constantCoeffs
             d             1e-4;
     air
         nu         1.48e-05;
         kappa      2.63e-2;
         Cp         1007;
         rho        1;
         constantCoeffs
             d              2.5e-3;
     lm //Soap or Surfactant
         nu         1.5e-05;
         kappa      1e-06;
         Cp         4195;
         rho        1060;
         constantCoeffs
             d               4e-5; //2nd try: 5e-5
sigmas
    (air water)     0.07
    (air oil)       0.03
    (air lm)        0.017
interfaceCompression
    (air water)     1
    (air oil)       1
    (air lm)        1
    (water oil)     0
    (water lm)      0
    (lm oil)        0
virtualMass
    (water oil)     0.2 //Change 19.08.2019
    (oil water)     0.2 //Change 19.08.2019
    (air oil)       0.4 //Change 23.08.2019
    (air water)     0.3 //Change 23.08.2019
    (lm water)      0.5
    (lm oil)        0.5
drag
    (air water)
        type blended;
        air
            type SchillerNaumann;
            residualPhaseFraction 0;
            residualSlip 0;
        water
            residualSlip 0;
        residualPhaseFraction 1e-3;
        residualSlip 1e-3;
    (air oil)
        type blended;
        air
            residualSlip 0;
        oil
            residualSlip 0;
        residualSlip 1e-3;
    (water oil)
        type blended;
        water
            residualSlip 0;
        oil
            residualSlip 0;
        residualSlip 1e-3;
    (air lm)
        type blended;
        air
            residualSlip 0;
        lm
            residualSlip 0;
        residualSlip 1e-3;
    (lm oil)
        type blended;
        lm
            residualSlip 0;
        oil
            residualSlip 0;
        residualSlip 1e-3;
    (lm water)
        type blended;
        lm
            residualSlip 0;
        water
            residualSlip 0;
        residualSlip 1e-3;
// This is a dummy to support the Smagorinsky model
transportModel  Newtonian;
nu              nu [ 0 2 -1 0 0 0 0 ] 0;
Turbulence Properties: LES
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    object      turbulenceProperties;
simulationType  LES;
LES
LESModel    Smagorinsky;
turbulence  on;
delta      maxDeltaxyz;
maxDeltaxyzCoeffs
    deltaCoeff 2;
Exampe for Velocity:
FoamFile
    version     2.0;
    format      ascii;
    class       volVectorField;
    location    "0";
    object      U.water;
dimensions      [0 1 -1 0 0 0 0];
internalField   uniform (0 0 0);
boundaryField
    wall
        type               fixedValue;
    value           uniform (0 0 0);
    atmosphere
        type               pressureInletOutletVelocity;
        value              $internalField;
        phi                phi.water;
p_rgh
FoamFile
    version     2.0;
    format      ascii;
    class       volScalarField;
    object      p_rgh;
dimensions      [1 -1 -2 0 0 0 0];
internalField   uniform 0;
boundaryField
    wall
        type            fixedFluxPressure;
        value           uniform 0;
    atmosphere
        type            totalPressure;
        p0              uniform 0;
        U               U.air;
        phi             phi.air;
    defaultFaces
        type            empty;
nut
FoamFile
    version     2.0;
    format      ascii;
    location    "0";
    object      nut;
dimensions      [0 2 -1 0 0 0 0];
boundaryField
    wall
        type            nutkWallFunction;
        value           uniform 0;
    atmosphere
        type            calculated;
        value           uniform 0;
    defaultFaces
        type            empty;
Stefanie.S.W. is offline   Reply With Quote
Old   August 26, 2019, 03:20
Stefanie Wolf
With the default settings the residuals looked like this:
Courant Number mean: 0.0221092 max: 0.998021
deltaT = 0.000116101
Time = 0.234055
MULES: Solving for alpha.water
water volume fraction, min, max = 0.262989 -5.51866e-06 0.976194
MULES: Solving for alpha.oil
oil volume fraction, min, max = 0.066948 -8.3735e-08 1
MULES: Solving for alpha.air
air volume fraction, min, max = 0.661929 -5.72097e-05 1
MULES: Solving for alpha.lm
lm volume fraction, min, max = 0.00813367 -1.28815e-07 0.0348452
Phase-sum volume fraction, min, max = 1 0.999995 1.00001
water volume fraction, min, max = 0.262989 -3.14167e-06 0.976192
oil volume fraction, min, max = 0.066948 -2.08892e-08 1
air volume fraction, min, max = 0.661929 -3.78788e-05 1
lm volume fraction, min, max = 0.00813367 -1.2732e-07 0.0348463
water volume fraction, min, max = 0.262989 -2.65234e-06 0.976189
oil volume fraction, min, max = 0.066948 -2.08932e-08 1
air volume fraction, min, max = 0.661929 -1.53512e-05 1
lm volume fraction, min, max = 0.00813367 -1.25778e-07 0.0348474
GAMG:  Solving for p_rgh, Initial residual = 0.00172755, Final residual = 1.08339e-05, No Iterations 3
time step continuity errors : sum local = 9.22853e-07, global = 6.84195e-09, cumulative = 7.93007e-05
GAMG:  Solving for p_rgh, Initial residual = 0.00052862, Final residual = 2.28243e-06, No Iterations 4
time step continuity errors : sum local = 1.93883e-07, global = 2.0161e-08, cumulative = 7.93209e-05
GAMGPCG:  Solving for p_rgh, Initial residual = 0.000145525, Final residual = 2.23163e-07, No Iterations 20
time step continuity errors : sum local = 1.89153e-08, global = -8.59243e-10, cumulative = 7.932e-05
ExecutionTime = 1009.12 s
with the changed settings in fvScheme and fvSolution I got the following error:
[4] #0  Foam::error::printStack(Foam::Ostream&) at ??:?
[4] #1  Foam::sigFpe::sigHandler(int) at ??:?
[4] #2  ? in "/lib/x86_64-linux-gnu/libc.so.6"
[4] #3  Foam::GAMGSolver::scale(Foam::Field<double>&, Foam::Field<double>&, Foam::lduMatrix const&, Foam::FieldField<Foam::Field, double> const&, Foam::UPtrList<Foam::lduInterfaceField const> const&, Foam::Field<double> const&, unsigned char) const at ??:?
[4] #4  Foam::GAMGSolver::Vcycle(Foam::PtrList<Foam::lduMatrix::smoother> const&, Foam::Field<double>&, Foam::Field<double> const&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::PtrList<Foam::Field<double> >&, Foam::PtrList<Foam::Field<double> >&, unsigned char) const at ??:?
[4] #5  Foam::GAMGSolver::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const at ??:?
[4] #6  Foam::fvMatrix<double>::solveSegregated(Foam::dictionary const&) at ??:?
[4] #7  Foam::fvMatrix<double>::solve(Foam::dictionary const&) in "/opt/openfoam6/platforms/linux64GccDPInt32Opt/bin/multiphaseEulerFoam"
[4] #8  ? in "/opt/openfoam6/platforms/linux64GccDPInt32Opt/bin/multiphaseEulerFoam"
[4] #9  __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
[4] #10  ? in "/opt/openfoam6/platforms/linux64GccDPInt32Opt/bin/multiphaseEulerFoam"
Last edited by Stefanie.S.W.; August 26, 2019 at 03:23. Reason: failed try to attache picture from wave between oil and water
Old   August 27, 2019, 05:11
Stefanie Wolf
Hello again,
attached is a picture of the oscillating behavior:
The movement starts "out of nowhere".
Here is my latest try to correct fvSchemes (simulation runs very fast and stable, less than 10 iterations needed per timestep) :
ddtSchemes
     default    CrankNicolson 0;
gradSchemes
divSchemes
    default                          none;
    "div\(phi.*,U.*\)"                 Gauss linearUpwindV grad(U);
    "div\(phi,alpha.*\)"               Gauss linearUpwind default;
    "div\(phir,alpha.*,alpha.*\)"      Gauss linearUpwind default;
     "div\(alphaPhi.*,U.*\)"           Gauss linearUpwind default;
    div((nuEff*dev(T(grad(U)))))      Gauss linear;
laplacianSchemes
  default   linear;
snGradSchemes
    default  limited 1;
Do you have an idea what could cause the oscillating behavior?
Old   August 27, 2019, 08:53
BlnPhoenix is on a distinguished road
Could the movement at the interface be due to momentum conservation of the riseing phases?
BlnPhoenix is offline   Reply With Quote
Old   August 27, 2019, 09:02
Also for a LES type of simulation your grid looks underresolved, this can be a potential problem.
Try running it in laminar first.
Old   August 27, 2019, 12:12
Arjun
arjun will become famous soon enougharjun will become famous soon enough
Originally Posted by Stefanie.S.W. View Post
Hello again,
I have worked with this type of issue in my Software called Wildkatze and one of the reasons for this behaviour is not proper balancing of gravitational force.
It requires very careful balancing of this force. It took me considerable efforts to get this right in Wildkatze (and at some expense of stability too).
A simple way to simulate this behaviour is to have two fluids separated and where heavy fluid is in bottom. (just like your case) and it shall produce 0 movement.
arjun is offline   Reply With Quote
Old   August 28, 2019, 05:15
Stefanie Wolf
Thank you a lot for the tips, BlnPhoenix and Arjun!
I am running a laminar test at the moment. Also I am working on refining my mesh.
Maybe I also need different divSchemes for different phases? And "stronger" solver?
converg condition, multiphase, multiphaseeulerfoam
Convergence Problems with turbulence kinetic energy Batou FLUENT 0 May 9, 2015 16:44
having problems with performing grid convergence study in SWFS drdet FloEFD, FloWorks & FloTHERM 12 January 22, 2015 05:44
Vorticity creates convergence problems? IngmarVanDijk FLUENT 6 November 12, 2014 11:50
NACA0012 Convergence Problems StudentAndrew CFX 6 November 21, 2005 07:49
Convergence problems Chetan FLUENT 3 April 15, 2004 20:13
