Oscillation in mesh refinement and unrefinement
Old   August 24, 2019, 09:17
Default Oscillation in adaptive mesh refinement
krishna kant
kk415 is on a distinguished road
Hello Foamers,
I am using dynamicMeshRefinement of OpenFoam and solving a static bubble test case. I am observing that a fix number of cell (i.e. 64) is getting refined and unrefined alternatively with the passage of time. Have anyone observed something like this before? What is the cause and remedy for this?
kk415 is offline   Reply With Quote
Old   August 31, 2019, 05:11
krishna kant
Hello Foamers,
I am attaching my output for your reference.
Courant Number mean: 1.69912e-07 max: 7.16164e-06
Interface Courant Number mean: 1.9221e-08 max: 6.04455e-06
Time = 0.09999
PIMPLE: iteration 1
Selected 112 cells for refinement out of 34896.
Refined from 34896 to 35680 cells.
Selected 0 split points out of a possible 1920.
Execution time for newMesh.update() = 0.44 s
Defining the group of the cells
MULES: Solving for alpha.water
Phase-1 volume fraction = 0.0316 Min(alpha.water) = 0 Max(alpha.water) = 1
solve the reinitialization equation
Interpolation of psi from coarser to finer mesh
Solve the modified reinitialization equation in finer mesh
Interpolation from finer to coarser mesh
DICPCG: Solving for p_rgh, Initial residual = 0.0100551, Final residual = 9.51849e-08, No Iterations 209
time step continuity errors : sum local = 2.11276e-14, global = -1.03739e-25, cumulative = 1.13937e-23
ExecutionTime = 115367 s ClockTime = 115435 s
Courant Number mean: 1.70292e-07 max: 7.16211e-06
Interface Courant Number mean: 1.92162e-08 max: 6.04469e-06
Time = 0.099995
PIMPLE: iteration 1
Selected 0 cells for refinement out of 35680.
Selected 112 split points out of a possible 1920.
Unrefined from 35680 to 34896 cells.
Execution time for newMesh.update() = 0.4 s
DICPCG: Solving for p_rgh, Initial residual = 0.0100496, Final residual = 9.16363e-08, No Iterations 220
time step continuity errors : sum local = 2.02673e-14, global = -3.25376e-25, cumulative = 1.10683e-23
ExecutionTime = 115375 s ClockTime = 115443 s
Courant Number mean: 1.69908e-07 max: 7.16148e-06
Interface Courant Number mean: 1.92202e-08 max: 6.04428e-06
Time = 0.1
PIMPLE: iteration 1
Execution time for newMesh.update() = 0.43 s
DICPCG: Solving for p_rgh, Initial residual = 0.0100549, Final residual = 9.61359e-08, No Iterations 209
time step continuity errors : sum local = 2.13378e-14, global = -1.83658e-25, cumulative = 1.08847e-23
ExecutionTime = 115383 s ClockTime = 115451 s
This problem is increasing my computational time and I am losing the advantage of AMR.
simpleDyMFoam on v1806 gamemakerh OpenFOAM Programming & Development 0 November 8, 2018 09:15
Error when combining mesh re-distribution with refinemt rribeiro OpenFOAM Programming & Development 0 March 24, 2015 15:47
