October 2, 2020, 00:16 |
#21 |
Anonymous.
Rep Power: 6 |
Hi have you tried the laserconvectionBC from tobais? I cant seem to get it to work.
Im running OFv2006. Which version did you run it on? How do I adapt it to latest OFv2006? |
October 7, 2020, 06:28 |
#22 | |
Bill
Rep Power: 7 |
Yes, I used the laserconvectionBC for OpenFoam-v1812 so I'm pretty sure it will work for v2006. I would need more details of your problem to help. One common error is forgetting to include "libs ( "liblaserConvectionBC.so" );" at the end of your controlDict file. Other than that, I don't know if I can help any more than the readme file that comes with the laserConvectionBC file. Hope that helps! |
October 15, 2020, 00:39 |
#23 | |
Anonymous.
Rep Power: 6 |
I manage to get it to work with v1912. Also, are you familiar with the solver icoreactingmultiphaseInterFoAM, I wanted to edit the files for my solid and liquid thermoproperties but could not find any guide to the symbols used. Do you know? Regards, gentodin |
October 25, 2020, 17:00 |
#24 |
ivanb
Good day. I was trying to use icoReact... solver and it does not work, thus i have many questions. What kind of boundary conditions should be applied to the irradiation surface? What kind of solvers did you use? Can you please share your case files for better understanding?
December 3, 2020, 06:47 |
laser scanning
#25 |
Rep Power: 6 |
Hello,everyone!
Does anyone know how to stop the scanning laser irradiation? When the scanning laser reaches the end point, the laser irradiation does not stop, and it seems that the irradiation continues at the end point. I want to know how to stop the irradiation when the scanning laser reaches the end point. Someone please give me some advice! |
December 11, 2020, 10:30 |
#26 | |
Jonas
Rep Power: 6 |
you don't happen to have found a way to get the BC work in OpenFOAM-v2006, do you? Working on a Cluster I only have access to the v2006 version and I can't seem to get the "wmake libso" function to compile it properly due to the changed syntax used.. Greetings, Jon |
March 9, 2021, 23:28 |
#27 |
Andersson Romero
Rep Power: 6 |
Hi, are you find any solution for marangoni effect?
May 19, 2021, 09:13 |
Foam fatal error "Current functionality limited to 3-D cases"
#28 | |
Harris Daniel S
Rep Power: 9 |
I happen to use the same Radiation properties file that you have put up here for the IcoReactingMultiphaseEulerFoam solver. But the file exits saying "Current functionality limited to 3-D cases" from the laserDTRM.C file line 234 where it checks "if (mesh_.nGeometricD() == 3)". I tried to print out what this function "mesh.nGeometricD()" returns. I returns 2. I know it has something to do with valid directions. Please let me know why I face this particular issue. Regards, Harris. Last edited by Harris_Daniel; May 25, 2021 at 07:51. |
August 8, 2021, 18:25 |
#29 |
James
Rep Power: 12 |
Hi ahomaru,
I developed a Marangoni convection model on a solver based on earlier version of interFoam. I could probably offer some help. But now I am looking forward to upgrade my model using icoReactingMultiPhaseInterFoam. Does this solver allow you to have metal and gas phase? I tried to change the standard solidMelting2D test case to include gas phase aswell but I was't succesfful so I wanted to know if you have included gas phase or not. Or if you know if it is possible to modify the tutorial case solidMelting2D to include gas phase? Best regards, |
August 19, 2021, 07:40 |
#30 | |
Harris Daniel S
Rep Power: 9 |
This icoReactingMultiPhaseInterFoam is a multi-phase solver that includes more than 2 phases. Marangoni convection can be introduced if you want to do so. Metal solids can also be included. |
November 12, 2021, 12:28 |
#31 | |
Rep Power: 5 |
i am still working on the implementation of the marangoni convection in icoReactingMultiphaseInterFoam. Maybe you could look into my Code and Testcase Setup. |
November 12, 2021, 17:22 |
#32 |
James
Rep Power: 12 |
November 13, 2021, 05:41 |
#33 |
Rep Power: 5 |
Not yet. I'll upload it soon.
November 14, 2021, 09:22 |
#34 |
Rep Power: 5 |
Here is a version of my Solver and Testcase. The Testcase is discussed in
Tan, L.H., Leong, S.S., Leonardi, E., Barber, T.J., 2006. A numerical study of solid-liquid phase change with Marangoni effects using a multiphase approach. Progress in Computational Fluid Dynamics, 6, 304-313 Feel free to ask questions. |
November 16, 2021, 11:37 |
Laser Heat Transfer
#35 |
DK
Rep Power: 5 |
Hello OPFO ,
I am getting this error over and again . I am using laserDTRM as a radiation Model .Please help us --> FOAM FATAL IO ERROR: (openfoam-2012) Unknown radiationModel type laserDTRM Valid radiationModel types : 6(P1 fvDOM none opaqueSolid solarLoad viewFactor) file: /home/dhar/OpenFOAM/dhar-v2012/run/heatTransfer/buoyantSimpleFoam/hotRadiationRoom/constant/radiationProperties at line 18 to 50. From static Foam::autoPtr<Foam::radiation::radiationModel> Foam::radiation::radiationModel::New(const volScalarField&) in file radiationModels/radiationModel/radiationModelNew.C at line 80. FOAM exiting |
November 16, 2021, 15:19 |
#36 |
Rep Power: 9 |
You can't use laserDTRM with buoyantSimpleFoam. It only works with icoReactingMultiphaseInterFoam.
The valid radiation models for buoyantSimpleFoam are printed in the error message. |
November 22, 2021, 13:50 |
#37 |
DK
Rep Power: 5 |
Hello OPFO , ahomaru , JonL
Which one will be T file ? Actually we are working on laser simulation using Solver ico reactingmultuphase . We are not able identify the Temperature file . |
November 25, 2021, 02:40 |
Laser Simulation in OpenFoam
#38 |
DK
Rep Power: 5 |
Hello OPFO ,
I am getting this error again over and again . Kindly help us . --> FOAM FATAL IO ERROR: (openfoam-2012) inconsistent patch and patchField types for patch type empty and patchField type fixedFluxPressure file: /home/sumantya/OpenFOAM/sumantya-v2012/run/solidMelting2D/0/p_rgh.boundaryField.frontAndBack at line 47. From static Foam::tmp<Foam::fvPatchField<Type> > Foam::fvPatchField<Type>::New(const Foam::fvPatch&, const Foam:imensionedField<Type, Foam::volMesh>&, const Foam::dictionary&) [with Type = double] in file /home/pawan/OpenFOAM/OpenFOAM/OpenFOAM-v2012/src/finiteVolume/lnInclude/fvPatchFieldNew.C at line 142. FOAM exiting |
November 25, 2021, 02:56 |
Laser Simulation
#39 |
DK
Rep Power: 5 |
hello OPFO ,
I am getting this error in laser simulation in OpenFoam [11:51 am, 25/11/2021] S_Nit_calicut: --> FOAM Warning : From void* Foam::dlLibraryTable:penLibrary(const Foam::fileName&, bool) in file db/dynamicLibrary/dlLibraryTable/dlLibraryTable.C at line 188 Could not load "liblaserConvectionBC.so" liblaserConvectionBC.so: cannot open shared object file: No such file or directory Create mesh for time = 0 PIMPLE: Operating solver in PISO mode Reading field p_rgh --> FOAM FATAL IO ERROR: (openfoam-2012) inconsistent patch and patchField types for patch type empty and patchField type fixedFluxPressure file: /home/sumantya/OpenFOAM/sumantya-v2012/run/solidMelting2D/0/p_rgh.boundaryField.frontAndBack at line 47. From static Foam::tmp<Foam::fvPatchField<Type> > Foam::fvPatchField<Type>::New(const Foam::fvPatch&, const Foam:imensionedField<Type, Foam::volMesh>&, const Foam::dictionary&) [with Type = double] in file /home/pawan/OpenFOAM/OpenFOAM/OpenFOAM-v2012/src/finiteVolume/lnInclude/fvPatchFieldNew.C at line 142. FOAM exiting |
January 8, 2022, 10:24 |
#40 |
Rep Power: 9 |
Try deleting
laserDTRMCoeffs { EDIT: In case you're wondering, the post I was replying to has been deleted. Last edited by Krapf; January 9, 2022 at 07:37. |
interfoam, laser melting, v1806 |
Pulsed laser udf | Sorabh | Fluent UDF and Scheme Programming | 4 | August 29, 2018 02:39 |
[ANSYS Meshing] Creating a Moving Heat Source in order to simulate a Laser | Lancer_21 | ANSYS Meshing & Geometry | 0 | August 28, 2018 11:39 |
Laser Ablation | MjG | Electromagnetics | 0 | March 7, 2018 16:28 |
Laser Ablation | MjG | ANSYS | 0 | March 5, 2018 16:13 |
Laser modeling in the laser cladding process | Piterhawk16 | STAR-CCM+ | 0 | December 25, 2017 09:01 |
