Wish to know the function of "stateConstructorTable::iterator cstrIter = sta"
Old   August 14, 2019, 10:39
Default Wish to know the function of "stateConstructorTable::iterator cstrIter = sta"
Bidesh Sengupta
BSengupta is on a distinguished road
Dear Foam Users,
Good Morning to you all!
I am trying to implement shallow water equation (related to my project) with ROE FLUX. The equations are:
Ut + Fx + Gy + Hz = 0, Here U = [rho, rho*u, rho*v, rho*w], F = [rho*u, rho*u*u + rho*rho, rho*u*v, rho*u*w], G = [rho*v, , rho*u*v, rho*v*v + rho*rho, rho*u*w] etc.
I have changed the necessary changes in NumericFlux, basicNumericFlux and roeFlux in dbnsFlux. When I compiled src it was compiled successfully.
Then, I was changed dbnsTurbFoam, but when I tried to compile it, I encountered errors:
/bidesh/foam/foam-extend-4.0/applications/bin/linux64GccDPOpt/dbnsDropletTurbFoam
/home/bidesh/foam/foam-extend-4.0/lib/linux64GccDPOpt/libdbns.so: undefined reference to `Foam::basicNumericFlux1::destroystateConstructorT ables()'
/home/bidesh/foam/foam-extend-4.0/lib/linux64GccDPOpt/libdbns.so: undefined reference to `Foam::basicNumericFlux1::constructstateConstructo rTables()'
/home/bidesh/foam/foam-extend-4.0/lib/linux64GccDPOpt/libdbns.so: undefined reference to `Foam::basicNumericFlux1::stateConstructorTablePtr _'
I suspect I could make some problems in addToRunTimeSelectionTable.H and runTimeSelectionTable.H.
I shall be really grateful if any Foamers can help to understand the problem and some hints to solve it.
Thank you very much for your time.
BSengupta is offline   Reply With Quote
compilation error, dbnsfoam, foam ext 4.0, openfoam
[mesh manipulation] RefineMesh Error and Foam warning jiahui_93 OpenFOAM Meshing & Mesh Conversion 4 March 3, 2018 12:32
[blockMesh] error message with modeling a cube with a hold at the center hsingtzu OpenFOAM Meshing & Mesh Conversion 2 March 14, 2012 10:56
ParaView for OF-1.6-ext Chrisi1984 OpenFOAM Installation 0 December 31, 2010 07:42
Compilation errors in ThirdPartymallochoard feng_w OpenFOAM Installation 1 January 25, 2009 07:59
Problem with compile the setParabolicInlet ivanyao OpenFOAM Running, Solving & CFD 6 September 5, 2008 21:50
