Rep Power: 7 ![]() |
Hello Everyone,
I am trying to calculate the local nusselt number along the bottom of a cavity heated from below. Based on inputs from several posts, I have tried to modify buoyantBoussinessqPimpleFoam to calculate temperature gradient. But, I am not sure if my procedure is right. Also I do not how to calculate the local Nusselt number. The values of grad T are unphysical. Kindly please help me solve this problem. I have attached the modified solver and a testCase. I am using OpenFOAM v6. The method of calculation of temperature gradient is as given below, which is added in the main file heatFoam.C Code:
//wallGrad const fvPatchList& patches = mesh.boundary(); forAll(wallGradT.boundaryField(), patchi) { const fvPatch& currPatch = patches[patchi]; if (isA<wallFvPatch>(currPatch)) { wallGradT.boundaryFieldRef()[patchi] = -T.boundaryFieldRef()[patchi].snGrad(); } } Code:
volScalarField wallGradT ( IOobject ( "wallGradT", runTime.timeName(), mesh, IOobject::NO_READ, IOobject::AUTO_WRITE ), mesh, dimensionedScalar ( "wallGradT", T.dimensions()/dimLength, 0 ) ); With Thanks & Regards, Pavithra. |
#2 | |||
Hojatollah Gholami
Nu=hL/K Nusselt number calculated based on the definition. In some article uses Nu=-wallGradT/(T-T_init)*L (L or D_h) and for that, you can use paraview and calculator for definition. Or uses swak4Foam in controlDic Quote:
code base on this topic Quote:
#3 | |
Dear Sir, Thank You somuch for your help and sorry for the late reply. I have used a similar method to calculate the Nusselt number. Thank You once again. - Pavithra |
Raul Cesar de Andrade Soares
Rep Power: 0 ![]() |
Could you give me the solver files with Nusselt's calculation? Did you have to change anything in the controldict? I also need to calculate the nusselt for the BuoyantBoussinesqPimpleFoam solver.
pimpleDyMFoam computation randomly stops | babapeti | OpenFOAM Running, Solving & CFD | 5 | January 24, 2018 05:28 |
SigFpe when running ANY application in parallel | Pj. | OpenFOAM Running, Solving & CFD | 3 | April 23, 2015 14:53 |
Compressor Simulation using rhoPimpleDyMFoam | Jetfire | OpenFOAM Running, Solving & CFD | 107 | December 9, 2014 13:38 |
Micro Scale Pore, icoFoam | gooya_kabir | OpenFOAM Running, Solving & CFD | 2 | November 2, 2013 13:58 |
How to write k and epsilon before the abnormal end | xiuying | OpenFOAM Running, Solving & CFD | 8 | August 27, 2013 15:33 |
