Initial and Final Residual of omega 0 by calculation with k-w turbulence model |
August 9, 2019, 18:03 |
Rep Power: 11 |
i'm trying to simulate an airfoil of an linear cascade. The mesh contains one airfoil and has periodic boundaries near the pressure and suction side. It is a q3d-case with only one layer, with a slip BC on the one sidewall and a symmetry BC on the other. The thermophysical properties are Perfect gas with constant thermodynamics and Sutherland for transport. Check mesh only complains about about high aspect ratio cells. But these are necessary for y+ values less then 1. I'm using the k-w turbulence model and the Smooth Solver for p, U, h, k and omega. The divergence scheme is Lust. As for the boundary conditions i choosed k = Low Re Wall Function and omega = Standard Wall Function (nu_t = Low Re Wall Function and alpha_T Standard) on the walls. The simulation runs fine and the residuals went beyond 1e-5 for Ux, Uy, Uz, p and k (h get stuck by ~1e-4). But here is the problem: The solver won't solve omega from the first timestep. Code:
velocityDampingConstraint velocityDamping damped 0 (0%) of cells smoothSolver: Solving for Ux, Initial residual = 3.597191e-007, Final residual = 6.192554e-008, No Iterations 2 smoothSolver: Solving for Uy, Initial residual = 2.276461e-007, Final residual = 4.008005e-008, No Iterations 2 smoothSolver: Solving for Uz, Initial residual = 1.496093e-005, Final residual = 5.666532e-008, No Iterations 8 smoothSolver: Solving for h, Initial residual = 8.749293e-005, Final residual = 1.187253e-008, No Iterations 8 smoothSolver: Solving for p, Initial residual = 8.486576e-007, Final residual = 5.21028e-007, No Iterations 102 smoothSolver: Solving for p, Initial residual = 6.523312e-007, Final residual = 4.989128e-007, No Iterations 102 smoothSolver: Solving for p, Initial residual = 5.678153e-007, Final residual = 4.820913e-007, No Iterations 102 time step continuity errors : sum local = 7.096876e-012, global = 6.886245e-012, cumulative = 0.0002020726 rho max/min : 1.209845 1.162966 smoothSolver: Solving for omega, Initial residual = 0, Final residual = 0, No Iterations 0 smoothSolver: Solving for k, Initial residual = 4.188657e-007, Final residual = 2.28007e-008, No Iterations 2 ExecutionTime = 934.098 s ClockTime = 934 s HTML Code:
https://www.cfd-online.com/Forums/openfoam-solving/81527-problem-sst-model-strange-behaviour.html Does anyone had to deal with the same error and found a solution? And what does it mean for the results when one field variable isn't solved? Greetings, Stuntmanbob Edit: I'm working on Windows10 with the free Version of SimFlow 3.1, which uses the OpenFoam 16.12. I also tried the same simulation with OpenFoam 7 (19.06) on ubuntu installed via the windows subsystem for linux. But the result is the same Last edited by Stuntmanbob; August 9, 2019 at 18:10. Reason: Additional information |
August 11, 2019, 10:10 |
#2 | |
Ruiyan Chen
Rep Power: 10 |
I've never used k-omega, but used k-epsilon quite a lot, which I think is pretty similar to k-omega in terms of how things are solved. |
August 16, 2019, 16:30 |
Rep Power: 11 |
thanks for the reply ich checked the omega and k distribution (see pics in the attachment). The omega values near the surface of the blade and in the wake are lower than in the main flow. The same with the k distribution. That seems fine to me. Another point is, that the min, max and average values of omega change during the simulation: Code:
volAverage() of omega = 2645.706 min(omega) = 1.153726 at location (0.2775581 0.01820756 0.0694632) max(omega) = 3.789602e+008 at location (0.1311357 0.2398932 0.0694632) Greetings, Stuntmanbob |
August 18, 2019, 06:02 |
#4 | |
Ruiyan Chen
Rep Power: 10 |
Okay, so omega does have a non-uniform distribution, which would mean that the omega equation is actually solved. Not sure what's going on. One thing that is similar to this is when you use the compressible solvers, for density, the log file always read
In the k-epsilon model, epsilon is the turbulence dissipation, so its maximum value could be very high. I've had something in the order of e+006, so I guess your max(omega) should be reasonable? Need some k-w experts here! |
Segmentation fault when using reactingFOAM for Fluids | Tommy Floessner | OpenFOAM Running, Solving & CFD | 4 | April 22, 2018 13:30 |
chtMultiRegionSimpleFoam turbulent case | Aditya Patil | OpenFOAM Running, Solving & CFD | 6 | April 24, 2017 23:13 |
simpleFoam error - "Floating point exception" | mbcx4jc2 | OpenFOAM Running, Solving & CFD | 12 | August 4, 2015 03:20 |
pimpleFoam: turbulence->correct(); is not executed when using residualControl | hfs | OpenFOAM Running, Solving & CFD | 3 | October 29, 2013 09:35 |
calculation stops after few time steps | sivakumar | OpenFOAM Running, Solving & CFD | 7 | March 17, 2013 07:37 |
