Scouring under submarine pipeline using sedFoam. |
August 8, 2019, 14:44 |
Md Akter Uz Zaman
Rep Power: 7 |
I want to simulate scouring under submarine pipeline using sedFoam, an openFOam solver for two phase flowsimulation. I am following the tutorial case '2DScour' but I could not able to run the attached geometry (picture 1). Actually I want to run simulation for two cases:
1. the pipe is just above the sediment (see picture 1) 2. and the pipe is partially buried (see picture 2) Can someone please help me how to run the desired simulation using the attached geometry? Thanks. |
November 2, 2019, 19:56 |
Cyrille Bonamy
Rep Power: 11 |
The good thread about sedfoam is here : https://www.cfd-online.com/Forums/op...-model-en.html
In addition, regarding the pipeline problem, a new 2Dpipeline tutorial is available on github : https://github.com/SedFoam/sedfoam/t...DPipelineScour |
How to simulate scouring under submarine pipeline using OpenFOAM? | Akter Uz Zaman | OpenFOAM Running, Solving & CFD | 0 | July 14, 2019 07:27 |
Hydrodynamic analysis of submarine model with ANSYS FLUENT? | Sovereignty | ANSYS | 0 | January 20, 2019 19:36 |
[ICEM] Hexa blocking a simple submarine | siw | ANSYS Meshing & Geometry | 1 | April 12, 2014 13:46 |
Bubbles in vertical pipeline | JM | Main CFD Forum | 1 | March 9, 2007 14:11 |
Crude oil Pipeline over river banks | Typical question in OIL and GAS | Main CFD Forum | 2 | October 15, 2006 09:33 |
