Controlling variable step size with a parameter other than Courant Number
Old   August 5, 2019, 08:00
Default Controlling variable step size with a parameter other than Courant Number
Mike Worth
MikeWorth is on a distinguished road
I'm using twoLiquidMixingFoam to model the washout of one fluid with another from a pipe. I can use the settings adjustTimeStep & maxCo to control the timesteps such that the flow is properly resolved, but this tends to result in output that doesn't show the washout in any detail.
Is it possible to add a condition of maximum change in overall system alpha (concentration)? That would allow me to clearly resolve the initial plug-flow washout, but then not waste loads of computation with a short timestep elsewhere in the simulation.
Thanks,
Mike
MikeWorth is offline   Reply With Quote
adjusttimestep, maxco, twoliquidmixingfoam
[General] Extracting ParaView Data into Python Arrays Jeffzda ParaView 30 November 6, 2023 22:00
decomposePar problem: Cell 0contains face labels out of range vaina74 OpenFOAM Pre-Processing 37 July 20, 2020 06:38
Courant Number waseeqsiddiqui FLUENT 3 December 27, 2018 11:43
Stuck in a Rut- interDyMFoam! xoitx OpenFOAM Running, Solving & CFD 14 March 25, 2016 08:09
Cluster ID's not contiguous in compute-nodes domain. ??? Shogan FLUENT 1 May 28, 2014 16:03
