Running dbnsFoam on a fully cyclic box
Old   July 26, 2019, 11:21
Default Running dbnsFoam on a fully cyclic box
Thomas
Roxxor91 is on a distinguished road
Hi everybody,
I want to run "dbnsFoam" on the a domain that is really just a 3D rectangle. I want to apply cyclic/periodic boundary conditions for every primitive variables and I wrote the "boundary" file that way:
6
    inbound
      type            cyclic;//patch;
        nFaces          8;
        startFace       192;
        matchTolerance 0.001;
        neighbourPatch outbound;
    top
        nFaces          10;
        startFace       200;
        neighbourPatch bottom;
    outbound
        nFaces          8;
        startFace       210;
        neighbourPatch inbound;
    bottom
        nFaces          10;
        startFace       218;
        neighbourPatch top;
    left
        nFaces          40;
        startFace       228;
        neighbourPatch right;
    right
        nFaces          40;
        startFace       268;
        neighbourPatch left;
However, the solver stops at the very beginning of the runTime.loop and shows:
Create time
Create mesh for time = 0
Reading thermophysical properties
Selecting thermodynamics package hPsiThermo<pureMixture<constTransport<specieThermo<hConstThermo<perfectGas>>>>>
Reading field rho
Reading field U
Selecting numericFlux rusanovFluxBarthJespersenLimiter
Reading field MDN
Reading analytic fields
Starting time loop
before compressibleCourantNo
Floating point exception (core dumped)
With GDB I figured out the problem has to come from "cyclicFvPatch::makeDeltaCoeffs(scalarField& dc)" (even though the execution seems to stop while reading "compressibleCourantNo.H" but I have no clue of what theses files are for at the moment.
Do you have any idea of what's causing the issue ?
Roxxor91 is offline   Reply With Quote
Setting up cyclic boundary condition KateEisenhower OpenFOAM Pre-Processing 6 January 11, 2017 18:17
LES in OF 3.0.1, no Output for nuSgs Mirage OpenFOAM Programming & Development 1 October 4, 2016 19:00
cyclic boundary violates mass conservation Maik OpenFOAM Running, Solving & CFD 13 August 23, 2016 10:25
Pressure instability with rhoSimpleFoam daniel_mills OpenFOAM Running, Solving & CFD 44 February 17, 2011 18:08
Immersol Simulation of a Heated Box Dong Phoenics 0 March 2, 2006 22:20
