DecomposePar: assign patch to processor
Old   July 25, 2019, 12:44
Default DecomposePar: assign patch to processor
Dozer_94 is on a distinguished road
Hi all,
I would like to know how to set up decomposeParDict in such a way that cells adjacent to a patch (i.e. owners of the patch faces) are all assigned to one processor. Consider this:
patch0
patch1
patch2
patch3
processor0: patch0, patch1
processor1: patch2, patch3
Thanks in advance,
Dozer_94 is offline   Reply With Quote
Old   July 31, 2019, 07:22
Carlo_P
Carlo_P is on a distinguished road
Hey,
if you want, you can take a look into the DecomposeParDict file here:
https://github.com/OpenFOAM/OpenFOAM...composeParDict
I think that in your case, you have to put the patch in preservePatches.
If the geometry is simple (such as a pipe), you can enforce the division in geoemtrical divisions using
method simple;
simpleCoeffs{ n (divisionInXDirection divisionInYDirection divisionInZDirection); delta 0.001; }
I would like to suggest to use the more coplex command only if you are very familiar with parallel computation. In the 99% the scoth method gives very good results
Carlo_P is offline   Reply With Quote
decomposepar, parallel
decomposePar problem: Cell 0contains face labels out of range vaina74 OpenFOAM Pre-Processing 37 July 20, 2020 06:38
[Other] dynamicTopoFVMesh and pointDisplacement RandomUser OpenFOAM Meshing & Mesh Conversion 6 April 26, 2018 08:30
decomposePar 4-core warning/error? Boloar OpenFOAM Bugs 23 April 8, 2014 09:57
Possible Bug in pimpleFoam (or createPatch) (or fluent3DMeshToFoam) cfdonline2mohsen OpenFOAM 3 October 21, 2013 10:28
Multicomponent fluid Andrea CFX 2 October 11, 2004 06:12
