interfoam parallel running exit code 145
Old   July 25, 2019, 04:40
Default interfoam parallel running exit code 145
kindi jan
fatlem is on a distinguished road
I have an issue running a simulation with interFoam solver (openfoam version 5.0.0).
My simulation is RANS k-w SST with VOF model of a free surface flow in channel managing a structure in it. and i am figuring out the velocity field around the structure and the head water.
After parallelizing my case, i run the solver, it takes about 1 or 2 days running and it gives me this error (i just copied the last part of the log file):
PIMPLE: iteration 1
smoothSolver: Solving for alpha.water, Initial residual = 4.097e-09, Final residual = 4.097e-09, No Iterations 0
Phase-1 volume fraction = 0.7029 Min(alpha.water) = -0.0002897 Max(alpha.water) = 1.007
MULES: Correcting alpha.water
GAMG: Solving for p_rgh, Initial residual = 0.2751, Final residual = 0.002164, No Iterations 13
time step continuity errors : sum local = 1.977e-10, global = 2.921e-12, cumulative = 4.478e-07
GAMG: Solving for p_rgh, Initial residual = 0.08213, Final residual = 7.147e-06, No Iterations 50
time step continuity errors : sum local = 1.634e-12, global = -3.544e-14, cumulative = 4.478e-07
smoothSolver: Solving for omega, Initial residual = 9.928e-07, Final residual = 9.928e-07, No Iterations 0
smoothSolver: Solving for k, Initial residual = 1.566e-06, Final residual = 3.268e-08, No Iterations 1
bounding k, min: 0 max: 1.439e+77 average: 4.407e+73
ExecutionTime = 7889 s ClockTime = 8363 s
surfaceFieldValue inletFlux write:
sum(inlet) of rhoPhi = -499.5
surfaceFieldValue outletFlux write:
sum(outlet) of rhoPhi = 0
surfaceFieldValue atmosphereFlux write:
sum(atmosphere) of rhoPhi = -7.511e+93
Courant Number mean: 1.834e-07 max: 8.948
Interface Courant Number mean: 1.22e-08 max: 2.914
deltaT = 1.279e-107
Time = 0.001915785357951
PIMPLE: iteration 1
smoothSolver: Solving for alpha.water, Initial residual = 4.094e-09, Final residual = 4.094e-09, No Iterations 0
Primary job terminated normally, but 1 process returned
a non-zero exit code.. Per user-direction, the job has been aborted.
mpirun detected that one or more processes exited with non-zero status, thus causing
the job to be terminated. The first process to do so was:
Process name: [[12165,1],3]
Exit code: 145
i tried to change the wall's conditions to wallfunctions and not y+=1 conditions but it does the same thing.
Can you help me figure out the problem? i didn't find the answer elsewhere. Thank you.
fatlem is offline   Reply With Quote
Old   July 25, 2019, 05:02
Rodrigo
guin is on a distinguished road
Something went wrong with the calculation already before the error. I suggest you to investigate further the reason for such big values for k:
guin is offline   Reply With Quote
Old   July 25, 2019, 05:04
Rodrigo
Same with the fluxes. I guess it became unstable at once.
Old   July 25, 2019, 05:05
Rodrigo
...indeed, this is the probe of it
deltaT = 1.279e-107
Old   July 26, 2019, 04:44
kindi jan
Thank you for your answer.
k is calculated with the equation (k=1.5*(UI)²) for the internalmesh and equal to zero at wall boudaries for y+=1 condition. i tried also with kwallfunction i gives me the same error.
Old   July 27, 2019, 08:48
Rodrigo
...unfortunately I don't have any expertise regarding turbulence nor wall models, but don't worry, his forum is plenty of more experienced users!
PS: Disregarding of that, this information may be insufficient to give a diagnostic of your problem. I suggest you to upload your case, so that other users can more efficiently help you to fix the settings.
Old   February 25, 2023, 08:58
Carlos
yvtzn is on a distinguished road
Hi! I have a similar error, but I see a few differences.
I'm trying to run my own case, but to be honest I'm actually learning.
Here the error:
PIMPLE: iteration 1
forces forces:
rho: rho
Not including porosity effects
Restraint translationDamper: force (0 0 8643.63)
Restraint rotationDamper: moment (-0 -15031.6 -0)
6-DoF rigid body motion
Centre of rotation: (3.5854 0 -0.10963)
Centre of mass: (3.5854 0 -0.10963)
Orientation: (0.981731 0 0.190275 0 1 0 -0.190275 0 0.981731)
Linear velocity: (-0 -0 -1.00618)
Angular velocity: (0 1.3262 0)
GAMG: Solving for pcorr, Initial residual = 1, Final residual = 0.0791026, No Iterations 3
time step continuity errors : sum local = 2.00954e-07, global = 2.21845e-08, cumulative = 2.86727e-07
smoothSolver: Solving for alpha.water, Initial residual = 0.000108711, Final residual = 5.08216e-11, No Iterations 9
Phase-1 volume fraction = 0.767756 Min(alpha.water) = -6.81899e-05 Max(alpha.water) = 1.00424
Applying the previous iteration compression flux
Phase-1 volume fraction = 0.767756 Min(alpha.water) = -0.00788331 Max(alpha.water) = 1.01183
a non-zero exit code. Per user-direction, the job has been aborted.
Process name: [[45478,1],3]
Exit code: 145
Also, I have to mention that previously I had another problem with my case. I tried to fix it by reducing the refinement boxes in the diferent topoSetDict.# and then it let me do:
mpirun -np 4 interFoam -parallel
after this comand, it begin to run and then the exit code 145 ocurred
I will apreciate info about this problem or just the right place guide or documentation to solve this, becasue as I said previously I'm to starting using OpenFoam and I don't know where to search.
Thank you so much for your help.
yvtzn is offline   Reply With Quote
exit code, interfoam, parallel error
OF 2.0.1 parallel running problems moser_r OpenFOAM Running, Solving & CFD 9 July 27, 2022 04:15
[snappyHexMesh] Error while running SnappyHex in parallel mg.mithun OpenFOAM Meshing & Mesh Conversion 1 February 10, 2016 14:13
Parallel running of 3D multiphase turbulence model (unknown problem!!) MOHAMMAD67 OpenFOAM Running, Solving & CFD 7 November 23, 2015 11:53
Issues running custom code in parallel BigBlueDart OpenFOAM Programming & Development 4 October 23, 2013 07:17
Something weird encountered when running OpenFOAM in parallel on multiple nodes xpqiu OpenFOAM Running, Solving & CFD 2 May 2, 2013 05:59
