July 24, 2019, 11:05 |
SonicFOAM Error- unknown error message
Rep Power: 7 |
Hello all,
I am using OpenFOAM v1812 on a high performance computer. I am attempting to model a simple geometric supersonic projectile in a compressible fluid. I chose sonicFOAM as my solver. The projectile is cylindrical with a hemispherical nose shape. I have modeled it within Fusion360 and imported it using the blockMesh, surfaceFeatureExtract, and snappyHexMesh utilities. The mesh generation seems to work fine. As shown by the following output messages of those utilities. blockmesh.out Code:
/*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: v1812 | | \\ / A nd | Web: www.OpenFOAM.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : v1812 OPENFOAM=1812 Arch : "LSB;label=32;scalar=64" Exec : blockMesh Date : Jul 22 2019 Time : 10:23:36 Host : nid04231 PID : 2373 I/O : uncollated Case : /p/work/ryanc6/run/OpenFOAM/SDb nProcs : 1 trapFpe: Floating point exception trapping enabled (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster (fileModificationSkew 10) allowSystemOperations : Allowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Creating block mesh from "/p/work/ryanc6/run/OpenFOAM/SDb/system/blockMeshDict" Creating block edges No non-planar block faces defined Creating topology blocks Creating topology patches Creating block mesh topology Check topology Basic statistics Number of internal faces : 0 Number of boundary faces : 6 Number of defined boundary faces : 6 Number of undefined boundary faces : 0 Checking patch -> block consistency Creating block offsets Creating merge list . Creating polyMesh from blockMesh Creating patches Creating cells Creating points with scale 0.0254 Block 0 cell size : i : 0.00635 .. 0.00635 j : 0.00846667 .. 0.00846667 k : 0.00846667 .. 0.00846667 There are no merge patch pairs Writing polyMesh with 0 cellZones ---------------- Mesh Information ---------------- boundingBox: (-0.4572 -0.3048 -0.3048) (0.4572 0.3048 0.3048) nPoints: 772705 nCells: 746496 nFaces: 2265408 nInternalFaces: 2213568 ---------------- Patches ---------------- patch 0 (start: 2213568 size: 46656) name: sides patch 1 (start: 2260224 size: 5184) name: inlet End snappyHexMesh.out Code:
No straight edges simplified and no points removed ... Snapped mesh : cells:2834400 faces:8580516 points:2912371 Cells per refinement level: 0 707296 1 55552 2 2063872 3 3584 4 4096 Writing mesh to time constant Wrote mesh in = 16.11 s. Mesh snapped in = 144.13 s. Checking final mesh ... Checking faces in error : non-orthogonality > 20 degrees : 137056 faces with face pyramid volume < 1e-13 : 0 faces with face-decomposition tet quality < 1e+15 : 8443460 faces with concavity > 50 degrees : 0 faces with skewness > 4 (internal) or 20 (boundary) : 0 faces with interpolation weights (0..1) < 0.05 : 0 faces with volume ratio of neighbour cells < 0.01 : 0 faces with face twist < 0.02 : 0 faces on cells with determinant < 0.001 : 0 Finished meshing with 8580516 illegal faces (concave, zero area or negative cell pyramid volume) Finished meshing in = 232.46 s. End sonicFOAM.out Code:
/*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: v1812 | | \\ / A nd | Web: www.OpenFOAM.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : v1812 OPENFOAM=1812 Arch : "LSB;label=32;scalar=64" Exec : sonicFoam Date : Jul 22 2019 Time : 10:28:18 Host : nid04231 PID : 2993 I/O : uncollated Case : /p/work/ryanc6/run/OpenFOAM/SDb nProcs : 1 trapFpe: Floating point exception trapping enabled (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster (fileModificationSkew 10) allowSystemOperations : Allowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create mesh for time = 0 PIMPLE: no residual control data found. Calculations will employ 2 corrector loops Reading thermophysical properties Selecting thermodynamics package { type hePsiThermo; mixture pureMixture; transport const; thermo hConst; equationOfState perfectGas; specie specie; energy sensibleInternalEnergy; } Reading field U Reading/calculating face flux field phi Creating turbulence model Selecting turbulence model type RAS Selecting RAS turbulence model kEpsilon RAS { RASModel kEpsilon; turbulence on; printCoeffs on; Cmu 0.09; C1 1.44; C2 1.92; C3 0; sigmak 1; sigmaEps 1.3; } Creating field kinetic energy K No MRF models present No finite volume options present Starting time loop Time = 0.2 Courant Number mean: 23317.8 max: 327563 diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0 PIMPLE: iteration 1 Application 13672019 exit codes: 136 Application 13672019 resources: utime ~14s, stime ~20s, Rss ~2810192, inblocks ~0, outblocks ~5394888 Code:
#0 Foam::error::printStack(Foam::Ostream&) at ??:? #1 Foam::sigFpe::sigHandler(int) at ??:? #2 ? in /lib64/libc.so.6 #3 Foam::symGaussSeidelSmoother::smooth(Foam::word const&, Foam::Field<double>&, Foam::lduMatrix const&, Foam::Field<double> const&, Foam::FieldField<Foam::Field, double> const&, Foam::UPtrList<Foam::lduInterfaceField const> const&, unsigned char, int) at ??:? #4 Foam::symGaussSeidelSmoother::smooth(Foam::Field<double>&, Foam::Field<double> const&, unsigned char, int) const at ??:? #5 Foam::smoothSolver::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const at ??:? #6 Foam::fvMatrix<Foam::Vector<double> >::solveSegregated(Foam::dictionary const&) at ??:? #7 Foam::fvMatrix<Foam::Vector<double> >::solveSegregatedOrCoupled(Foam::dictionary const&) at ??:? #8 Foam::fvMesh::solve(Foam::fvMatrix<Foam::Vector<double> >&, Foam::dictionary const&) const at ??:? #9 ? at ??:? #10 __libc_start_main in /lib64/libc.so.6 #11 ? at /home/abuild/rpmbuild/BUILD/glibc-2.19/csu/../sysdeps/x86_64/start.S:125 _pmiu_daemon(SIGCHLD): [NID 04231] [c8-1c0s1n3] [Mon Jul 22 10:28:52 2019] PE RANK 0 exit signal Floating point exception ryanc6 |
July 31, 2019, 16:00 |
Giovanni Medici
Rep Power: 12 |
Apparently the timestep you are using is way too high, the Courant number shall be at most < than 1 (in principle you could reach values slightly higher than 1 with pimple).
So I would suggest trying to reduce timestep. The sonicDyMFoam solver carries the possibility to adapt the timestep to a specified Courant value (my personal opinion is that this approach works only when some degree of convergence has been reached, otherwise, e.g. in the first part of the computation, it is very likely to obtain oscillations of timestep hence courant that may lead to divergence). I would strongly suggest you to take a look to (and inspiration from) the tutorials for sonicFoam and sonicDyMFoam. |
energy in sonicFoam | joern | OpenFOAM Running, Solving & CFD | 1 | September 24, 2019 00:15 |
SonicFoam tuto nacaAirfoil steadystate | Dorian1504 | OpenFOAM Running, Solving & CFD | 10 | October 11, 2017 17:05 |
Bug/Problem: sonicFoam results depend on relaxation factor | chriss85 | OpenFOAM Bugs | 1 | November 5, 2015 08:22 |
Error trying to run steady-state sonicFoam | dancfd | OpenFOAM Running, Solving & CFD | 2 | February 12, 2013 03:15 |
Crash when using sonicFoam | Horus | OpenFOAM | 1 | June 16, 2010 12:57 |
