#21 |
Carmelo Baronetto
Rep Power: 2 ![]() |
Thank you, indeed I can see some diffusion.
I tried also the case of two gases at different temperature. Also in this case, diffusion occurs. I compared results obtained with reactingFoam and rhoCentralFoam for temperature diffusion: 1) For very high viscosity, both simulations give same results; 2) For real viscosity values, diffusion is much more faster in rhoCentralFoam. I have to invastigate further and compare numerical results with analytical solutions. I don't know if anyone else has encountered these strange behaviors of the solvers. Thank you |
#22 | |
Carmelo Baronetto
First of all, reactingFoam seems to work well. The problem is with rhoCentralFoam. If I set viscosity: ![]() I got these results:
https://we.tl/t-C0GA4p2ap3 It's really strange beacuse for inviscid flow, rhoCentralFoam should directly avoid to solve Navier-Stokes equations. Thank you |
mixing plane model: too much backflow and does not converge | sbhi | FLUENT | 1 | December 4, 2014 00:31 |
fluid zone in mixing & transport reaction model | rahulangal | FLUENT | 0 | June 6, 2010 11:40 |
multiphase mixing Problem with MRF model in MixSim | Srinivas | FLUENT | 0 | October 17, 2005 06:35 |
Floworks: Mixing and thermal analysis of two gases | Jay Nelson | Main CFD Forum | 0 | June 14, 2005 18:29 |
