Multiple Phases inflow and outflow - Boundary Conditions
Old   July 23, 2019, 14:56
Default Multiple Phases inflow and outflow - Boundary Conditions
Vitor Heitor Cardoso
heitorvitorc is on a distinguished road
Hey guys,
I'm working on multiphase flow in porous media on microscale, using interFoam solver, and I need to validate the simulation with an experiment consisting on oil displacement in a microchannel. Thus, I prepared a 3D rectangle in gmsh and set it as filled with oil, in order to inject water.
It seems like the simulations are not returning physical sense, as the oil phase is not leaving the domain. I kindly ask for the community help to evaluate which are the proper boundary conditions for the alpha.water, p_rgh and U dictionaries, as I am new to such matters. Here are the assumptions:
Fully saturated channel;
Water is injected;
Oil leaves the channel as water moves into outlet.
Incompressible flow.
I appreciate any kind of help. Thanks in advance.
Best regards,
Vitor
FoamFile
    version     2.0;
    format      ascii;
    class       volScalarField;
    location    "0";
    object      alpha.oil;
dimensions      [0 0 0 0 0 0 0];
internalField   uniform 1;
boundaryField
    FrontAndBack
        type            empty;
    Inlet
        type            fixedValue;
        //inletValue      uniform 0;
        value           uniform 1;
    BottomWall
        type            zeroGradient; // ignoring surface tension effects
    Outlet
        type            inletOutlet;
        value          uniform 0;
    TopWall
FoamFile
    version     2.0;
    format      ascii;
    object
 p_rgh
; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [1 -1 -2 0 0 0 0]; internalField uniform 0; boundaryField { Inlet { type fixedValue; value uniform 10; } Outlet { type fixedValue; value uniform 0; } TopWall { type zeroGradient; } BottomWall { type zeroGradient; } FrontAndBack { type empty; } }
FoamFile
    version     2.0;
    format      binary;
    class       volVectorField;
    location    "0";
    object      U;
dimensions      [0 1 -1 0 0 0 0];
internalField   uniform (0 0 0);
boundaryField
    FrontAndBack
        type            empty;
    Inlet
        type            pressureInletOutletVelocity;
        value           uniform (0 0 0);
    TopWall
        type            noSlip;
    Outlet
        type            zeroGradient;
    BottomWall
        type            noSlip;
heitorvitorc is offline   Reply With Quote
Old   August 30, 2019, 02:55
Stefanie Wolf
Stefanie.S.W. is on a distinguished road
Hello Vitor,
did you try a fixed velocity inlet and a pressure outlet?
I think that those are quite easy BCs to begin with and have a 1st test run.
Maybe a fixed value inlet BC will work for you. It is used in the nozzleFlow tutorial. (interFoam les)
u_inlet
type fixedValue;
value uniform (x y z);
u_outlet
type zeroGradient;
prgh_inlet
prgh_outlet
type fixedValue;
value uniform 0;
Maybe a massFlowRate inlet would also work? (as in the angledDuct tutorial?)
Best,
Stefanie
Stefanie.S.W. is offline   Reply With Quote
Old   December 21, 2020, 23:36
Default Boundary condition setting
Rohit
Rohitsingh is on a distinguished road
Send a message via Skype™ to Rohitsingh
Originally Posted by heitorvitorc View Post
Hey guys,
Water is injected;
Best regards,
Vitor
FoamFile
    version     2.0;
    format      ascii;
    location    "0";
    object      alpha.oil;
boundaryField
    FrontAndBack
        type            empty;
    Inlet
        type            fixedValue;
        value           uniform 1;
    BottomWall
    Outlet
        type            inletOutlet;
        value          uniform 0;
    TopWall
FoamFile
    version     2.0;
    format      ascii;
    object
 p_rgh
FoamFile
    version     2.0;
    format      binary;
    location    "0";
    object      U;
boundaryField
    FrontAndBack
        type            empty;
    Inlet
    TopWall
        type            noSlip;
    Outlet
        type            zeroGradient;
    BottomWall
        type            noSlip;
I am also having same problem, can you share the solution if you resolved your problem?
Rohitsingh is offline   Reply With Quote
My radial inflow turbine Abo Anas CFX 27 May 11, 2018 02:44
Centrifugal fan-reverse flow in outlet lesds to a mass in flow field xiexing CFX 3 March 29, 2017 11:00
Out File does not show Imbalance in % Mmaragann CFX 5 January 20, 2017 11:20
Basic Nozzle-Expander Design karmavatar CFX 20 March 20, 2016 09:44
potentialFoam doesnt start?! Sway OpenFOAM Running, Solving & CFD 0 July 2, 2015 08:48
