Why the change of writeInterval will cause simulation crash? |
July 12, 2019, 10:19 |
Huang, Chiung Shu
Rep Power: 8 |
Hi Foamers,
I am facing a problem which is ... when I running my simulation, it will crash at different simulation time when I set different writeInterval value in controlDict file. For example, the control dict below /*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: v1812 | | \\ / A nd | Web: www.OpenFOAM.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; object controlDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // libs ("liboverset.so"); DebugSwitches { overset 0; dynamicOversetFvMesh 0; cellVolumeWeight 0; } application overInterDyMFoam ; startFrom latestTime; startTime 0.0; stopAt endTime; endTime 15; deltaT 0.001; writeControl adjustableRunTime; writeInterval 0.5; purgeWrite 0; writeFormat ascii; writePrecision 6; writeCompression off; timeFormat general; timePrecision 6; runTimeModifiable yes; adjustTimeStep yes; maxCo 1.5; maxAlphaCo 2; maxDeltaT 1; ------------------------------------------------------------------------- With the configuration my case will simulate longer than the writeInterval value = 0.1, and then crashed. I don't know why the different output interval will cause different result??? Is because of the it will re-read the output and causing not continuous simulation? Any idea will appreciated!! |
March 26, 2020, 17:42 |
Yan Zhang
Rep Power: 12 |
Did you find the solution?
https://openfoam.top |
How to change the number of parcels at each patch with simulation time step | AJAY BHANDARI | OpenFOAM Pre-Processing | 7 | December 23, 2018 17:49 |
variable composition mixture phase change simulation | WXS | CFX | 0 | September 26, 2018 01:14 |
[rhoCentralFoam] Crash in Nozzle Simulation | maxmax | OpenFOAM Running, Solving & CFD | 6 | June 3, 2015 16:51 |
Simulation crash with dynamicRefineFvMesh and kOmegaSST - OF 2.3.x | nathanael | OpenFOAM Running, Solving & CFD | 4 | June 29, 2014 18:02 |
Change BCs during simulation | tav98f | CFX | 2 | September 27, 2011 17:00 |
