ERROR: request for volScalarField thermo:psi from objectRegistry region0 |
July 8, 2019, 11:09 |
Abdelrahman Abouali
Hello
I am trying to run a case based on the tutorial "hotroom" using buoyantBoussinesqPimpleFoam. I have changed the boundary conditions as I need to have an inlet wind and an outlet that's open to the atmosphere and the ceiling as well. I have only the side walls and the ground as Wall Type. I run the blockMesh then decompose the case and run setFields on parallel, all this is normal without errors. But when I try to run the solver I get this error: Code:
--> FOAM FATAL ERROR: [2] request for volScalarField thermo:psi from objectRegistry region0 failed available objects of type volScalarField are 11 ( rhok nut alphaEff k p_rgh nu gh alphat p T epsilon ) [2] [2] [2] From function const Type& Foam::objectRegistry::lookupObject(const Foam::word&) const [with Type = Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>] [2] in file /home/ubuntu/OpenFOAM/OpenFOAM-4.1/src/OpenFOAM/lnInclude/objectRegistryTemplates.C at line 193. [2] FOAM parallel run aborting Code:
defaultFieldValues ( volScalarFieldValue T 300 ); regions ( // Set patch values (using ==) boxToFace { box (4.5 1.5 -1000) (5.5 2.5 1e-5); fieldValues ( volScalarFieldValue T 500 ); } ); Code:
wall : floor scalar nut generic scalar k generic scalar p_rgh fixedFluxPressure scalar alphat generic scalar p calculated scalar T fixedValue scalar epsilon generic vector U noSlip patch : ceiling patch : outlet scalar nut calculated scalar k calculated scalar p_rgh totalPressure scalar alphat calculated scalar p calculated scalar T totalTemperature scalar epsilon calculated vector U pressureInletOutletVelocity patch : inlet scalar nut calculated scalar k calculated scalar p_rgh zeroGradient scalar alphat calculated scalar p calculated scalar T fixedValue scalar epsilon calculated vector U fixedValue wall : sideWalls scalar nut generic scalar k generic scalar p_rgh fixedFluxPressure scalar alphat generic scalar p calculated scalar T zeroGradient scalar epsilon generic vector U noSlip Thanks in advance! |
September 19, 2020, 05:53 |
#2 | |
Haoyu Zhai
I faced the same error, have you fixed it yet? I checked the source code of buoyantBoussinesqPimpleFoam and can't find 'thermosi' in it. Quote:
boundaries, heat transfer |
request for volScalarField k from objectRegistry region0 failed+(DPMFoam) | abdollahi | OpenFOAM Programming & Development | 41 | January 7, 2020 14:14 |
chtMultiRegionSimpleFoam: crash on parallel run | student666 | OpenFOAM Running, Solving & CFD | 3 | April 20, 2017 12:05 |
[waves2Foam] objectRegistry region0 failed | gautami | OpenFOAM Community Contributions | 3 | November 15, 2016 13:14 |
request for surfaceScalarField corrected from objectRegistry region0 failed | immortality | OpenFOAM Running, Solving & CFD | 7 | May 7, 2015 22:00 |
reconstructParMesh not working with an axisymetric case | francesco | OpenFOAM Bugs | 4 | May 8, 2009 06:49 |
