Capturing hot surface ignition
Old   July 7, 2019, 20:04
Default Capturing hot surface ignition
Bjørn is on a distinguished road
I am attempting to model spontaneous ignition of a premixed gas mixture as it travels through a domain with hot surfaces.
When the gas enters it about 30 deg Celsius. The hot surfaces should be the source of ignition.
The gas consists of CO2, CH4, N2 and O2
I have looked at the forums and could not find anything on ignition from hot surfaces, so the question follows:
What would be the best solver for this problem?
regards,
Bjørn
Bjørn is offline   Reply With Quote
hot surface, ignition, premixed combustion, sovler
[Gmsh] Problem with Gmsh nishant_hull OpenFOAM Meshing & Mesh Conversion 23 August 5, 2015 03:09
[snappyHexMesh] Snap Precision to a STL Surface malaboss OpenFOAM Meshing & Mesh Conversion 16 July 26, 2013 02:44
[snappyHexMesh] Layers don't fully surround surface EVBUCF OpenFOAM Meshing & Mesh Conversion 14 August 20, 2012 05:31
killed "snappyHexMesh" parkh32 OpenFOAM Pre-Processing 2 April 8, 2012 18:12
Surface capturing prettyflower OpenFOAM Running, Solving & CFD 2 January 27, 2009 08:24
