dynamicMeshDict for two rotating bodies
Old   July 7, 2019, 14:24
Talking dynamicMeshDict for two rotating bodies
Kondorfa is on a distinguished road
Hi all,
How can one rotate two bodies in OpenFOAM v1812.
I just cannot figure out what entries to put where in the dynamicMeshDict.
I can find different examples for other (elder) versions of OpenfOAM, but they only create errors.
For one body it is the follwing:
| \\ / O peration | Version: v1812 |
| \\ / A nd | Web: www.OpenFOAM.com |
| \\/ M anipulation | |
FoamFile
version 2.0;
format ascii;
class dictionary;
location "constant";
object dynamicMeshDict;
dynamicFvMesh dynamicMotionSolverFvMesh;
motionSolverLibs ( "libfvMotionSolvers.so" );
motionSolver solidBody;
cellZone innerPartSmall;
solidBodyMotionFunction rotatingMotion;
origin (0 0 0);
axis (0 1 0);
omega 94.2;
Any ideas?
K.
Kondorfa is offline   Reply With Quote
Old   July 7, 2019, 15:28
CFD USER
CFD_10 is on a distinguished road
You can use multiSolidBodyMotionFvMesh.
Here is an example: Multiple AMI rotations not working
CFD_10 is offline   Reply With Quote
Old   July 7, 2019, 17:08
CFD_10, Thanks a lot for pointing to this previous thread.
I tried multiSolidBodyMotionFvMesh and got this error message below. Hence the second option mentioned in the thread using dynamicMultiMotionSolverFvMesh seems promosing.
I try and report later.
[1] Unknown dynamicFvMesh type multiSolidBodyMotionFvMesh
Valid dynamicFvMesh types are :
6
dynamicInkJetFvMesh
dynamicMotionSolverListFvMesh
dynamicRefineFvMesh
staticFvMesh
Old   July 7, 2019, 17:18
CFD USER
Sorry, I think that multiSolidBodyMotionFvMesh is available only in OpenFOAM versions from OpenFOAM Foundation (openfoam.org) but for ESI OpenCFD version (openfoam.com), OFv1812 I think dynamicMultiMotionSolverFvMesh is the equivalent.
Old   July 7, 2019, 17:28
Thumbs up
dynamicMultiMotionSolverFvMesh now seems to work. Yupiee!
Thanks a lot for this quick help!!
K.
dynamicmeshdict, rotational motion, two bodies
[ANSYS Meshing] ANSYS 2D Geometry/Meshing Plugin Error: Attach Failed, No Valid Bodies Found cdase ANSYS Meshing & Geometry 0 August 26, 2018 15:31
Car external aerodynamic with wheel spinning issue hokhay FloEFD, FloWorks & FloTHERM 2 August 18, 2016 05:23
Rotating Impeller Naith FloEFD, FloWorks & FloTHERM 22 November 5, 2012 09:53
On rotating bodies using dynamicFvMesh ebah6 OpenFOAM Pre-Processing 2 January 30, 2012 17:08
Y+ on rotating bodies Luiz Eduardo Bittencourt Sampaio Main CFD Forum 4 July 13, 2001 11:55
