How to calculate muCoeffs and kappaCoeffs for compressible fluid? |
July 5, 2019, 05:57 |
Priyanka P
Rep Power: 7 |
Hello Everyone,
I am using chtMultiRegionSimpleFoam solver, and my OpenFoam version is 4.1. I have question related to thermophysical properties. I am using Polynomial transport model, In this model, I have to calculate muCoeffs and kappaCoeffs in terms of temperature. The description is available on the following link: https://cfd.direct/openfoam/user-gui...hermophysical/ But I don't know how to calculate it. Can someone please guide me through this? Thank you |
June 24, 2020, 13:34 |
kappaCoeffs -Thermophysical properties
Vipinkumar c p
Rep Power: 6 |
Hi priyanaka
You can create polynomial co-efficient by formulating equation using Microsoft excel sheet.For example to get kappacoeff 1. Create a scatter plot of Temp vs thermal conductivity 2. right click on line on the plot then add trend-line 3. in trend line option select polynomial and the set the order of the polynomial 4.Check display equation on the chart 5.copy the co-efficient value of the equation |
June 26, 2020, 09:12 |
Joachim Herb
Rep Power: 22 |
For instructions how to fit the Sutherland viscosity model, follow these instructions:
https://curiosityfluids.com/2019/04/...-using-python/ But you can do a polynomial fit as well, following these instruction by changing the corresponding function. |
openfoam, thermophysical parameters |
