error in compressibleInterFoam
Old   July 3, 2019, 10:58
Default error in compressibleInterFoam
cyw
Yuanwei Cao
cyw is on a distinguished road
Recently, I am simulating the bubble rising in water with heat transfer using compressibleInterFoam solver. But when I start from the latestTime, there is an error in the following, could anyone give me a hint about the reason?
Lookup solver for TFinal
smoothSolver: Solving for T, Initial residual = 0.0076371, Final residual = 8.40008e-09, No Iterations 5
[60] #0 Foam::error:rintStack(Foam::Ostream&)[36] #0 Foam::error:rintStack(Foam::Ostream&)[15] #0 Foam::error:rintStack(Foam::Ostream&) at ??:?
at ??:?
[15] #1 Foam::sigFpe::sigHandler(int)[36] #1 Foam::sigFpe::sigHandler(int) at ??:?
[60] #1 Foam::sigFpe::sigHandler(int) at ??:?
[15] #2 ? at ??:?
[36] #2 ? at ??:?
[60] #2 ?Lookup gradScheme for nHat
Cache: Calculating nHat, originating from alpha.water event No. 624
in /lib64/libc.so.6
[15] #3 in /lib64/libc.so.6
[36] #3 in /lib64/libc.so.6
[60] #3 ???Lookup interpolationScheme for interpolate(nHat)
at ??:?
[15] #4 Foam::H2O::rho(double, double) const at ??:?
[36] #4 Foam::H2O::rho(double, double) const at ??:?
[60] #4 Foam::H2O::rho(double, double) const at ??:?
[15] #5 Foam::species::thermo<Foam::thermophysicalProperti esSelector<Foam::liquidProperties>, Foam::sensibleInternalEnergy>::Es(double, double) const at ??:?
[36] #5 Foam::heThermo<Foam::rhoThermo, Foam:ureMixture<Foam::species::thermo<Foam::ther mophysicalPropertiesSelector<Foam::liquidPropertie s>, Foam::sensibleInternalEnergy> > >::he(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&) const at ??:?
[60] #5 Foam::heThermo<Foam::rhoThermo, Foam:ureMixture<Foam::species::thermo<Foam::ther mophysicalPropertiesSelector<Foam::liquidPropertie s>, Foam::sensibleInternalEnergy> > >::he(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&) const at ??:?
[15] #6 Foam::species::thermo<Foam::thermophysicalProperti esSelector<Foam::liquidProperties>, Foam::sensibleInternalEnergy>::T(double, double, double, double (Foam::species::thermo<Foam::thermophysicalPropert iesSelector<Foam::liquidProperties>, Foam::sensibleInternalEnergy>::*)(double, double) const, double (Foam::species::thermo<Foam::thermophysicalPropert iesSelector<Foam::liquidProperties>, Foam::sensibleInternalEnergy>::*)(double, double) const, double (Foam::species::thermo<Foam::thermophysicalPropert iesSelector<Foam::liquidProperties>, Foam::sensibleInternalEnergy>::*)(double) const) const at ??:?
[36] #6 Foam::twoPhaseMixtureThermo::correctThermo() at ??:?
[60] #6 Foam::twoPhaseMixtureThermo::correctThermo() at ??:?
[36] #7 at ??:?
[60] #7 at ??:?
[15] #7 Foam::heRhoThermo<Foam::rhoThermo, Foam:ureMixture<Foam::species::thermo<Foam::ther mophysicalPropertiesSelector<Foam::liquidPropertie s>, Foam::sensibleInternalEnergy> > >::calculate(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>&, bool)?? at ??:?
[15] #8 Foam::heRhoThermo<Foam::rhoThermo, Foam:ureMixture<Foam::species::thermo<Foam::ther mophysicalPropertiesSelector<Foam::liquidPropertie s>, Foam::sensibleInternalEnergy> > >::correct() at ??:?
[36] #8 __libc_start_main at ??:?
[60] #8 __libc_start_main at ??:?
[15] #9 Foam::twoPhaseMixtureThermo::correctThermo() in /lib64/libc.so.6
[36] #9 in /lib64/libc.so.6
[60] #9 at ??:?
[15] #10 ??? at /home/abuild/rpmbuild/BUILD/glibc-2.22/csu/../sysdeps/x86_64/start.S:121
at ??:?
[15] #11 __libc_start_main in /lib64/libc.so.6
[15] #12 ? at /home/abuild/rpmbuild/BUILD/glibc-2.22/csu/../sysdeps/x86_64/start.S:121
cyw is offline   Reply With Quote
error
