Darcy solver with boussinesq assumption. Solver crashes for zero gradient BC for Temp |
July 3, 2019, 08:47 |
Manu Chakkingal
Rep Power: 10 |
Hello All
I am trying to solver Darcy flow equation with boussinesq assumption. I simulate bottom heated top cooled 2D cavit with adiabatic sidewalls. The solver gives unphysical unbounded Temperature, when I give zeroGradient BC for T (adiabatic). However it doesnt crash when instead of adiabatic I give a fixed temperature value for the side walls as well(fixedValue BC). Solver details below: Code:
/*---------------------------------------------------------------------------*\ ========= | \\ / F ield | foam-extend: Open Source CFD \\ / O peration | Version: 4.0 \\ / A nd | Web: http://www.foam-extend.org \\/ M anipulation | For copyright notice see file Copyright ------------------------------------------------------------------------------- License This file is part of foam-extend. foam-extend is free software: you can redistribute it and/or modify it under the terms of the GNU General Public License as published by the Free Software Foundation, either version 3 of the License, or (at your option) any later version. foam-extend is distributed in the hope that it will be useful, but WITHOUT ANY WARRANTY; without even the implied warranty of MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU General Public License for more details. You should have received a copy of the GNU General Public License along with foam-extend. If not, see <http://www.gnu.org/licenses/>. Application laplacianFoam Description Solves a simple Laplace equation, e.g. for thermal diffusion in a solid. \*---------------------------------------------------------------------------*/ #include "fvCFD.H" #include "singlePhaseTransportModel.H" #include "simpleControl.H" // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // int main(int argc, char *argv[]) { # include "setRootCase.H" # include "createTime.H" # include "createMesh.H" simpleControl simple(mesh); # include "readGravitationalAcceleration.H" # include "createFields.H" // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Info<< "\nCalculating flow and temperature distribution\n" << endl; while (simple.loop()) { Info<< "Time = " << runTime.timeName() << nl << endl; #include "pEqn.H" #include "TEqn.H" # include "write.H" Info<< "ExecutionTime = " << runTime.elapsedCpuTime() << " s" << " ClockTime = " << runTime.elapsedClockTime() << " s" << nl << endl; } Info<< "End\n" << endl; return 0; } // ************************************************************************* // Code:
{ //phi = fvc::interpolate(U) & mesh.Sf(); surfaceScalarField phiG(Mf*fvc::interpolate(rhok)*(g & mesh.Sf())); //Test // surfaceScalarField phiG(Mf*ghf*fvc::snGrad(rhok)*mesh.magSf()); // phi += phiG; // while (simple.correctNonOrthogonal()) // { fvScalarMatrix pEqn ( //fvm::laplacian(-Mf,p) + fvc::div((fvc::interpolate(rhok) * Mf)* (g & mesh.Sf())) fvm::laplacian(-Mf,p)+ fvc::div(phiG) ); // pEqn.relax(); pEqn.setReference(pRefCell, pRefValue); pEqn.solve(); // phi= (phiG + fvc::snGrad(p)*Mf*mesh.magSf()); // if (simple.finalNonOrthogonalIter()) // { // phi= (phiG+pEqn.flux()); // p.relax(); //Reconstruct the velocity field. //Velocity isnt involved in any calculation //multiplied by fluid density to convert to velocity //If needed the BC can be set using DarcyPressure BC , where velcoity is converted to pressure U=fvc::reconstruct ( phi ); // U = fvc::reconstruct(phi); U.correctBoundaryConditions(); // } } Code:
{ //Solve 1 temperature equation for combined solid and fluid phase fvScalarMatrix TEqn ( fvm::laplacian(DT, T)== (eps*rhoCpf+(1.-eps)*rhoCps)*fvm::ddt(T) + rhoCpf*fvm::div(phi,T) ); // TEqn.relax(); TEqn.solve(); //Density updation based on temperature p/rho is used in implementation //rhok thus doesnt have unit of density but dimensionless rhok=rhof*(1.0 - (beta*(T - TRef))); //solve pressure Eqn. Mf account for K/mu. //PhiG in createfields takes care of density induced flux } Could someone help me to find why zeroGradient BC fails and not fixedValue Regards manu
Regards Manu Last edited by manuc; July 3, 2019 at 09:03. Reason: not complete |
PEMFC model with FLUENT | brahimchoice | FLUENT | 22 | April 19, 2020 16:44 |
[ANSYS Meshing] Help with element size | sandri_92 | ANSYS Meshing & Geometry | 14 | November 14, 2018 08:54 |
Periodic flow using Cyclic - comparison with Fluent | nusivares | OpenFOAM Running, Solving & CFD | 30 | December 12, 2017 06:35 |
fluent divergence for no reason | sufjanst | FLUENT | 2 | March 23, 2016 17:08 |
Star cd es-ice solver error | ernarasimman | STAR-CD | 2 | September 12, 2014 01:01 |
