Discussion on AMR with interFoam
Old   July 3, 2019, 04:17
Default Discussion on AMR with interFoam
krishna kant
kk415 is on a distinguished road
Hello Foamers
I am about to start working with AMR in interFoam (interDyMFoam). I would like to know what are its limitations and what kind of problem can it solve. Some of the limitation I think there is AMR works in 3D and not in 2D.
Also is there any ways I can control the division of cells in AMR. Like I want my grid to remain Cartesian if it is Cartesian.
Thanks
kk415 is offline   Reply With Quote
Old   August 21, 2019, 00:57
krishna kant
Hello Again,
So I found out AMR works in 2D as well as 3D but the boundary condition can't be empty now in the third direction. AMR works for 2D problem if the boundary condition in the 3rd direction is cyclic(periodic) or symmetry. I have verified this through a vortex stretching test case, static bubble and a rising bubble.
AMR gives very good result for the vortex stretching case. But fails in the static bubble case. So now I am again in doubt. Is AMR good only to give better preservation of mass and not the balance between Surface Tension and Pressure forces?
Information about the case setup used in static bubble test case is as following:
A circular bubble of radius r=0.005at equilibrium kept at (0.025,0.025) in a square domain of 0.05×0.05. Density ratio of 1000. Surface Tension ��=0.01. For the given parameters the analytical solution is ∆��=2. Plot at t=0.1, ∆X=1/100 and ∆t=5e-6.
Please find the picture attached with this for your reference.
interFoam vs. simpleFoam channel flow comparison DanM OpenFOAM Running, Solving & CFD 12 January 31, 2020 16:26
interFoam (HELYX-OS) pressure boundary conditions SFr OpenFOAM Running, Solving & CFD 8 June 23, 2016 17:36
k-e & GAMG interFoam Schemitisation Stability Issue JFM OpenFOAM Running, Solving & CFD 3 December 1, 2015 06:58
interFoam in parallel gooya_kabir OpenFOAM Running, Solving & CFD 0 December 9, 2013 06:09
Problem of InterFoam with LES SpalartAllmarasIDDES keepfit OpenFOAM 3 August 29, 2013 12:21
