Problem with 3weeks Day2
Old   July 2, 2019, 18:00
Default Problem with 3weeks Day2
momentumv is on a distinguished road
I tried to follow the Tutorial in the 3 week course, and on day2 it has Turtorial Three from http://cfd.at/downloads/FoamTutV4_3-ExampleThree.pdf.
The example ran fine until I tried to change the mesh density to 100 cells (as suggested by the tutorial), and then it solves up to time step 0.00459 when it crashes with a Negative initial temperature T0: -13.1838
Not sure what the issue is.
momentumv is offline   Reply With Quote
Old   July 2, 2019, 18:04
**Edit** this was because I was comparing the 1 bar that I ran to the 10 bar that was reported. ***/edit**** I also was getting max Courant numbers of half that reported by the tutorial pdf.
Old   July 2, 2019, 18:12
Increasing the time step for the solution from 1 e-5 to 1 e-4 solves the problem, but I don't understand why a very small courant number would lead to unstable Temperatures causing the crash.
[Other] engineFoam new mesh problem ayhan515 OpenFOAM Meshing & Mesh Conversion 5 August 10, 2015 09:45
UDF compiling problem Wouter Fluent UDF and Scheme Programming 6 June 6, 2012 05:43
Gambit - meshing over airfoil wrapping (?) problem JFDC FLUENT 1 July 11, 2011 06:59
natural convection problem for a CHT problem Se-Hee CFX 2 June 10, 2007 07:29
Adiabatic and Rotating wall (Convection problem) ParodDav CFX 5 April 29, 2007 20:13
