July 2, 2019, 11:33 |
interDyMFoam vs. multiphaseInterDyMFoam
Emily
Rep Power: 8 |
I'm a relatively new user of openFOAM and am trying to decide which solver would be best for me to use. I'm modeling slosh in a tank where gravity is very low and surface tension forces become important. Because of this, it seems like multiphaseInterDyMFoam is probably the best solver because the description mentions the ability to specify contact angle and surface tension. But any other user I've talked to working on similar problems have used interDyMFoam, and I can't seem to see any difference between the tutorial files. I don't see contact angle defined anywhere in the multiphaseInterDyMFoam tutorial case, and it seems like you can specify surface tension in interDyMFoam anyway. Does anyone have any experience with low-gravity two-phase flows who prefers one over the other? Thanks! |
July 4, 2019, 04:32 |
#2 | |
Vignesh S P
Rep Power: 8 |
I don't know much about multiPhaseInterDyMFoam but adding contact angles for the case can be given through boundary conditions of alpha.(phaseName) Pleae read the linked thread How to use constant alpha contact angle in OF 2.1.1 |
July 5, 2019, 10:08 |
#3 | |
Emily
Rep Power: 8 |
July 5, 2019, 10:22 |
Vignesh S P
Rep Power: 8 |
Pleasure and best wishes
interdymfoam, multiphaseinterdymfoam, solvers |
interDyMFoam with VOF + 6DOF instable | pbalz | OpenFOAM Running, Solving & CFD | 11 | October 9, 2020 06:19 |
Restart InterDymFoam simulation from latestTime | Giovanni_Do | OpenFOAM Running, Solving & CFD | 2 | April 11, 2019 06:22 |
Standard InterDyMFoam doesn't work after modifying interFoam | nesca87 | OpenFOAM Running, Solving & CFD | 7 | January 5, 2017 23:47 |
modifying interDyMFoam for floatingObject | Elisabeth_ofoam | OpenFOAM Programming & Development | 7 | June 11, 2014 09:42 |
error using interDyMFoam with kOmegaSST to simulate sloshing | anmartin | OpenFOAM Running, Solving & CFD | 0 | July 20, 2010 14:21 |
