Can I use OverPimpleDyMFoam and 6DOF rigid body motion at the same time? |
Lee SiHun
Rep Power: 7 ![]() |
Hi, fellow Foamers, I'm new to openfoam and was wondering if I can use OverpimpleDyMFoam and 6 DOF rigid body motion library at the same time.
So, what I would like to do is to make an airfoil with torsional and heaving stiffness to run a time domain flutter analysis. I was able to run overpimpledymfoam with mesh generated from fluent and couple it with prescribed motion using multiSolidBodyMotionSolver. But as I see it, SixDOFRigidBodyMotion solver requires "inner distance" and "outer distance" which deformes the mesh itself. In order not to deform mesh topology (using overset mesh) and run sixDOFRigidBodyMotion, what should I do? Thanks in advance! |
Yann
Rep Power: 27 ![]() |
Yes it is possible, have a look at the dynamicMeshDict of the floatingBody tutorial in overInterDyMFoam. Cheers, Yann |
