alphaContactAngle for reactingMultiphaseEulerFoam
Old   July 1, 2019, 12:25
Default alphaContactAngle for reactingMultiphaseEulerFoam
amin.z's Avatar
Amin
amin.z is on a distinguished road
Hi everybody,
I wanna use alphaContactAngle BC for a reactingMultiphaseEulerFoam solver, which I suppose should look like as follows:
1915     theWall
1916     {
1917         type            alphaContactAngle;
1918         thetaProperties
1919        (
1920        ( air water ) 90 0 0 0
1921        ( air oil      ) 90 0 0 0
1922        ( oil water ) 90 0 0 0
1923        );
1924        value           uniform 0;
1925    }
after running it I get the following error :
--> FOAM FATAL IO ERROR:
wrong token type - expected word, found on line 1920 the punctuation token ')'
I'm using exactly same pattern as the tutorials, does any body has an idea what's wrong here?
BTW having a contact angle calculation might sound wierd for an Euler solver, but it's included in both reactingMultiphaseEulerFoam and multiphaseEulerFoam.
amin.z is offline   Reply With Quote
Old   September 28, 2021, 06:47
GV871 is on a distinguished road
I have the same problem, have you found the error ?
GV871 is offline   Reply With Quote
Mass conservation problem with multiphaseInterFoam alphaContactAngle andresbh OpenFOAM 6 April 19, 2023 10:06
alphaContactAngle parameters: in which file to define? makaveli_lcf OpenFOAM Running, Solving & CFD 0 April 8, 2013 09:25
alphaContactAngle not recognized robosys541 OpenFOAM Running, Solving & CFD 0 August 21, 2012 17:41
alphaContactAngle patch type does not work in OF-1.6 sundaero OpenFOAM Bugs 10 April 13, 2012 19:08
alphaContactAngle lakshay26 OpenFOAM 1 April 27, 2011 05:52
