June 27, 2019, 20:54 |
Setting Static Pressure in interFoam
Suresh raja
Rep Power: 12 |
I am setting up a draining of liquid from a pipeline case. The pipeline is draining out the liquid due to a rupture. How should I set the initial pressure which is about 1000 psig? Is this set using the internal Field?
June 28, 2019, 04:21 |
Sita Drost
Rep Power: 18 |
Hi Suresh,
Yes, if I understood your case correctly, that's the way I'd do it. Cheers, Sita |
initial condition, interfoam, openfoam 1806 |
Setting Fan Static Pressure | low.xuanyi | Phoenics | 1 | January 9, 2020 12:42 |
What is difference between static pressure and gauge pressure? | aja1345 | FLUENT | 1 | July 20, 2018 21:05 |
error: uninitialized local variable 't' used | MASOUD | Fluent UDF and Scheme Programming | 5 | October 17, 2016 05:24 |
Setting up the pressure variation due to tornado in a duct(UDF)+animation | guillaume1990 | FLUENT | 0 | March 3, 2014 12:59 |
Assign static pressure at inlet | Tanjina | FLUENT | 0 | November 3, 2013 12:34 |
