Adding a source term to the epsilon equation
Old   June 26, 2019, 18:40
Default Adding a source term to the epsilon equation
anon_q is on a distinguished road
Hello
In my computational domain I want to add a source term to the \varepsilon equation of the k-\varepsilon turbulence model using the fvOptions framework.
The source term depends on the distance from the inlet and the velocity:
S_{\varepsilon} =  {5x\over U}
Where x is distance from the inlet boundary condition and U is the local x-velocity.
How can I use fvOptions to achieve that?
Thank you
anon_q is offline   Reply With Quote
Old   May 3, 2020, 00:55
René Thibault
Tibo99 is on a distinguished road
Hi!
Did you find a solution?
I got the same issue here...trying to add a source term to k-e model?
Tibo99 is offline   Reply With Quote
[swak4Foam] Installation Problem with OF 6 version Aurel OpenFOAM Community Contributions 14 November 18, 2020 16:18
Adding a source term to k and epsilon equation for buoyancy rajeshkunwar OpenFOAM Running, Solving & CFD 2 April 19, 2019 07:41
Adding a Source Term to Pressure equation pEqn in SimpleFoam oscar_urri OpenFOAM 11 February 22, 2018 17:52
[swak4Foam] Error bulding swak4Foam sfigato OpenFOAM Community Contributions 18 August 22, 2013 12:41
DxFoam reader update hjasak OpenFOAM Post-Processing 69 April 24, 2008 01:24
