flowRateOutletVelocity BC for compressible application
Old   June 26, 2019, 14:00
Default flowRateOutletVelocity BC for compressible application
Mat
Mat_fr is on a distinguished road
Hi Foamers,
I would like to use the flowRateOutletVelocity boundary condition with a compressible fluid (I am using compressibleInterFoam).
I want to impose a mass flow rate, so I am using the following specifications:
        type                flowRateOutletVelocity;
        massFlowRate        0.03;
        rho                 rho;
With this settings, I am getting the following error
--> FOAM FATAL ERROR:
Did not find registered density field rho and no constant density 'rhoOutlet' specified
which is strange as the volScalarField rho is speficied in my time folder.
I don't want to use a constant density to estimate the mass flow rate (as with rhoOutlet option), but I want to use the density field rho computed by the solver.
Is it even possible ?
Thanks for your help,
Mat
Mat_fr is offline   Reply With Quote
Old   June 27, 2019, 06:18
Joachim Herb
jherb is on a distinguished road
It might be thermo:rho or something like rho.air or even thermo:rho.air
jherb is offline   Reply With Quote
Old   June 27, 2019, 07:24
Mat
Good call, but unfortunately it's not working either. I have tried the different combinations.
Old   June 27, 2019, 07:33
Joachim Herb
Ok, then perhaps this helps:
First try a different boundary condition to get it to run at all. Then also add a writeObject funtion object to the controlDict with object "banana". This should show all available object in the internal database.
https://github.com/OpenFOAM/OpenFOAM...s/writeObjects
Old   June 27, 2019, 08:55
Mat
Thanks for your help Joachim,
None of the fields in the list given by the writeObject funtion solves this error. Which is strange.
I have tried also with the flowRateInletVelocity boundary condition, but it's the same problem.
When I look to a tutorial example (for instance in tutorials/compressible/rhoPimpleFoam/RAS/squareBendLiq/0/U), we can see the following BC:
inlet
type flowRateInletVelocity;
massFlowRate constant 5;
rhoInlet 1000; // Guess for rho
Perhaps the comment means that rhoInlet is only used as a guess for the first time step, and then the inlet velocity is adapted in function of the given flow rate and the calculated rho ?
Should be the same with the outlet BC then.
Regards,
Mat
Old   June 27, 2019, 09:24
Joachim Herb
This is the source code of the boundary condition:
https://github.com/OpenFOAM/OpenFOAM...orField.C#L185
So if it does not find a field with the name for rho, you have specified, it tries to use rhoOutlet (see also the description in the header file: https://github.com/OpenFOAM/OpenFOAM...hVectorField.H)
It is not an initial guess but used as constant during the whole run.
But I still do not understand, why it does not find rho: The field is defined in the solver: https://github.com/OpenFOAM/OpenFOAM...teFields.H#L44
But is this field (the weighted average density) what you want for your boundary? Otherwise, two density fields are references here: https://github.com/OpenFOAM/OpenFOAM...teFields.H#L41
If you modify this file, you might get the names by adding something like (not tested):
Info<<"rho1: "<< rho1.name() << endl;
Info<<"rho2: "<< rho2.name() << endl;
Which version of OpenFOAM do you use?
Old   June 27, 2019, 09:47
Mat
I am using openfoam-6.
I got the names with your piece of code:
rho1: thermo:rho.h2
rho2: thermo:rho.water
Already tried them, and still the same error.
Old   July 2, 2019, 04:42
Joachim Herb
One last idea: What is in the "object" name in the header of the files with the density stored in the time directory?
|  \\    /   O peration     | Version:  5.x                                   |
|   \\  /    A nd           | Web:      www.OpenFOAM.org                      |
FoamFile
    version     2.0;
    format      ascii;
    class       volScalarField;
    location    "200";
    object      XXXXXX;
Old   July 2, 2019, 15:01
Mat
Hi
Thanks a lot for your time.
The header specifies "rho", but it's still not working.
I have made the test with the compressible/rhoPimpleFoam/RAS/squareBendLiq tutorial.
By default for this tutorial, the inlet BC for U is using a constant density and reads:
    inlet
        massFlowRate    5.0;
And if I change it for a variable density with the lines below, it is working in this case!
    inlet
        massFlowRate    5.0;
        rho             rho;
So I think it is a problem of compatibility between the solver and the BC.
Regards,
Mat
Old   July 4, 2019, 06:22
Joachim Herb
I guess your are right. You might try to get an answer from the OpenFOAM foundation by posting this problem on their bug tracker: https://bugs.openfoam.org/
You most probably get a request for funding to implement it, but perhaps also an explanation, why it does not work.
You could try to call db().foundObject<volScalarField>(rhoName_) (or mesh.foundObject<volScalarField>(rhoName_) ) in the solver itself with different names and output, if something was found.
Perhaps, the boundary conditions are evaluated the first time before the rho field exists. But this is just a guess. Another one is, that the name is not correct (some permutation of thermo/rho/rho1/rho.water/...
You could try to add
SimpleFoam cannot open include file Marija OpenFOAM Running, Solving & CFD 1 October 28, 2020 11:35
Error in compute process - No Active Application yetlyg FLUENT 8 October 27, 2018 23:30
Ansys Licence Serve on Ubuntu 16.04 LTS david.pasquale ANSYS 2 January 20, 2017 12:52
Is Playstation 3 cluster suitable for CFD work hsieh OpenFOAM 9 August 16, 2015 15:53
what should we do for the application of CUDA in CFD? aerosjc Main CFD Forum 6 February 25, 2013 12:01
