Computer time to drain liquid from pipeline due to rupture |
June 24, 2019, 01:15 |
Suresh raja
Rep Power: 12 |
I am looking to see if I can use OpenFoam to predict the flow rate and time to drain out oil from a pipeline due to a rupture (may be modeled as an orifice). This is a incompressible flow but needs to be solved by first starting with the pipeline completely filled. Once the rupture in the pipeline occurs, the pump will be shut off. I am looking to predict the flow rate and the time to drain. The pipeline will also have variations in elevations that follow the terrain. Could you please let me know which tutorial file and the best solver that would suit this problem? Thanks for reading and for your help! |
June 24, 2019, 05:56 |
Kumar
Rep Power: 13 |
This should be doable with interFoam solver.
June 25, 2019, 00:45 |
Thanks!
Suresh raja
Rep Power: 12 |
Thanks kishpishar.
drainage, incompressible, opeanfoam, pipeline, rupture |
bash script for pseudo-parallel usage of reconstructPar | kwardle | OpenFOAM Post-Processing | 42 | May 8, 2024 00:17 |
[General] Extracting ParaView Data into Python Arrays | Jeffzda | ParaView | 30 | November 6, 2023 22:00 |
LES, Courant Number, Crash, Sudden | Alhasan | OpenFOAM Running, Solving & CFD | 5 | November 22, 2019 03:05 |
High Courant Number @ icoFoam | Artex85 | OpenFOAM Running, Solving & CFD | 11 | February 16, 2017 14:40 |
dynamic Mesh is faster than MRF???? | sharonyue | OpenFOAM Running, Solving & CFD | 14 | August 26, 2013 08:47 |
